Old Nov 1st, 2005, 09:02 PM   #1 (permalink)
TheEnchantor
Checking/refilling Manual transmission fluid on 1.6l 200SX
I want to check the transmission oil level on my 95 200SX because there seems to a small leak and its been 30k or so since it was changed (at least they charged me for it!). The Haynes book suggests that this done by removing the speed sensor. I removed the lock down screw and I can rotate the thing around but it won't come out, at least with what I consider to be reasonable force.
Is there some trick to getting this thing out or do I need a big hammer?
TheEnchantor is offline   Reply With Quote
Old Nov 1st, 2005, 09:25 PM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
No hammer just a twisting and pulling motion. It is plastic and will break if you use a hammer or large pry bar. Although I did have some success with twisting it so that the screw flange is exposed and gently prying it up.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Transmission fluid check youngwp Truck & SUV 2 Sep 1st, 2005 06:24 PM
Manual Transmission Problems 86nissan Truck & SUV 6 Apr 16th, 2005 06:47 AM
200sx S-ER transmission limitations? 200sx SR-Series Engines (DE/VE) 1 Mar 21st, 2004 05:13 PM
Transmission Fluid Replacement RedfordRules J30 1989-1994 Chassis 11 Sep 6th, 2003 12:18 AM
Manual Transmission Fluid Aaron SR-Series Engines (DE/VE) 12 Sep 11th, 2002 09:21 PM
