Missing IAT (Intake Air Temperature) Sensor - Nissan Forum
post #1 of 7 Old Oct 4th, 2005, 05:10 PM Thread Starter
Question Missing IAT (Intake Air Temperature) Sensor
I've been reading some of the posts and I have a pretty good understanding of my air intake system. My problem is that I can't find this sensor! I see the circles on the airbox where the sensor mounting holes would be but it looks like thats for other models. I understand that there are two types and the other one plugs into the main hose or into the snout. I've been feeling around and looking for hours and I can't even find a place for a sensor to go. It is not modified in any way that I can tell. I have had this car for 2 weeks. There is a trouble code P0110 (IAT Sensor Circuit Failure) so that is why im looking for it. I did find something interesting though, there is a 2 wire harness plug hanging loose in the fender well on the intake side. Obviously I looked in the vicinity but there isn't anything within reach of the plug. My guess is that it was removed and lost or something. I know its only used for ODB-II diagnosis so it isn't extremely important but it is annoying. Thank you for any feedback you can provide.
Elektron82 is offline
post #2 of 7 Old Oct 4th, 2005, 05:16 PM
Still here
thecolonelcm's Avatar
Send a message via AIM to thecolonelcm
I believe that harness is the one for the IAT sensor.
See this post for further reference. I have the same car as you cept mine is 5spd so i think our bays should be similar.
*pics*
http://www.nissanforums.com/showpost...5&postcount=15
If for some reason there is no sign of it there, talk to Wildmane. His IAT sensor comes from the loom that into the MAF so it could potentially be there.
*pics*
http://www.nissanforums.com/showpost...9&postcount=16
thecolonelcm is offline
post #3 of 7 Old Oct 4th, 2005, 06:32 PM Thread Starter
Bingo! That is the harness plug that I have, the one in your post not Wildmane. Do you remember if the sensor went into the snout or was it just hanging or what? I still can't find a place in the snout where it would go. I think the snout is probably from a doner car designed like Wildmane's. Im sure it isn't original since it would have been knocked out in the accident in '99. I wonder if the previous owner never noticed it and just gave up... So I guess I just need to get one of them there sensors and tie it to the fender well so the ECM will shut up and be happy. Thanks a lot for replying! If I had searched a little more I probably would have found that and could have saved an extra posting but oh well.
post #4 of 7 Old Oct 4th, 2005, 08:41 PM
Still here
If your car still has the the stock airboxsetup, there is a T shaped hose that goes between your battery and the drivers side fender. It leads down to a box behind the foglight. The IAT sensor plugs into the T shaped hose. There should be a bung that you can twist the sensor in. If that fitting isnt there for some reason, find a way to mount it near the filter.
I havent tried this but i would imagine you could cut a bung in the lower half of the airbox (before the filter) and plug in there. I'm not aware if your sensor will reach that location but its a thought. Could you post some pics of your engine bay.. preferably of the area in question and i could better assist ya.
Good luck.
post #5 of 7 Old Oct 8th, 2005, 07:25 PM
hdt
hdt's Avatar
ITA
you are corret on the location. in goes on the t shaped tube on the end of your stock intake system. if you have a custom or after market intake there should be a hole to plug it in. mine has started to show the code. so just check it.
97gxe sentra. ga16de, auto, cold air intake, catback,15inch rims,rockford sterio system,apc tack,apc fire bottle,
led neon under car kit, plugs,wires, sturt tower brace front and rear. coil overs, sway bars. drift front and rear kit, with exstream sides. jim wolf ecu, jim wolf cams.new mods ( junk yard in the sky ) RIP 14 aug 06 6am
2008 altima 2.5sl pebble beach. stock for now. bought 26may08 7:30pm
1964 ford falcon 2dr hardtop. 200 inline 6
2003 sporttrac xlt gold 260whp. xcal tune,intake,spacer, and full exhaust system
gone but not forgotten,
2004 buick rendezvous cx traded.
1997 nissan sentra gxe rip
1998 ford contur se sport
1992 ford excort lx hatchback
1980 chevy scottsdale 350,585 cranck hp
1987 isuzu pup
1964 vw bug
hdt is offline
post #6 of 7 Old Mar 18th, 2009, 06:48 PM
could somebody upload the pics again please
LOKO13 is offline
post #7 of 7 Old Mar 24th, 2009, 01:39 AM
could somebody upload the wiring diagram or one picture of the engine to see where it goes.. please !!!!!......
LOKO13 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
OBD II Code Chart no1see2me QG18 1.8L Engine 9 Jul 26th, 2009 03:26 PM
Intake air temp sensor cliff437 New Member Forum 3 Nov 22nd, 2004 07:46 PM
Cold Air Intake Kristian S14 240SX 1995-1998 17 May 18th, 2004 03:05 AM
Custom Intake glowsentra B13 91-94 chassis 21 Aug 19th, 2003 07:10 AM
Questions about air intake... dschrier B11/B12/KN13 82-90 chassis 2 May 31st, 2002 04:53 PM
You may post new threads
You may post replies
BB code is On
