Help! Nissan Sentra won't start! - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Dec 8th, 2002, 10:52 PM   #1 (permalink)
Unhappy Help! Nissan Sentra won't start!
OK, you've heard this before. Car won't start. Sounds easy, but... here's the details..
This has been a historical problem with this Nissan Sentra 1.6l efi, every winter.
The starter motor turns the engine. At first the car almost starts - some cylinders fire - , then the engine just turns.
I pulled plug 1 and have spark- also gas in the cylinder.. The tanks not empty either - over 1/4 tank.
I tried dry gas - no change.
Last year I installed 100,000 platimum plugs (Bosch). I pulled them (they loook good) and touched them up a bit just to make sure.
I changed the distributor cap, rotor and wires.
Also changed the air filter ( no other air restrictions either), the PCV valve (of course the V in PCV stands for valve, so PCV Valve is redundant, but this isn't English class) and the fuel filter.
Oh yeah - there's no potatoe in the tailpipe either.
Is there some known problem with cold-weather starting?
Anyone have any ideas??
biggie5747 is offline   Reply With Quote
Old Dec 8th, 2002, 10:54 PM   #2 (permalink)
Nissan Fanatic
Send a message via AIM to By Nature
how old is your battery?
"Those who stand for nothing, will fall for anything"
2003 VW Jetta 1.8
1998 Nissan Sentra 1.6
By Nature is offline   Reply With Quote
Old Dec 8th, 2002, 11:00 PM   #3 (permalink)
It's not the battery. If it were, the starter motor would not turn the engine over. Just to make sure, I use a separate die-hard that I keep charged, and run it in parallel for more cranking amps.
Old Dec 8th, 2002, 11:06 PM   #4 (permalink)
Sentra Specialist
blownb310's Avatar
Re: Help! Nissan Sentra won't start!
[i]
Anyone have any ideas?? [/B]
**** Yes, the car is flooded. The problem is the Coolant Temp. sensor. It's in the intake manifold. Replace it. Then change the oil and filter too, because it will be fuel saturated, and is aggravating the problem further. If the plugs are not too fouled, you can start it by simply pulling the fuel pump fuse, and cranking over [with foot on the gas to allow air into the engine], until it starts. If not, then you'll have to change the plugs too.
'93 SE-R
'93 E model [oval track]
'91 SE-R [rallycross]
'89 B12 4WD [GA16DET]
'81 Datsun 210
'77 Datsun B210
blownb310 is offline   Reply With Quote
Old Dec 10th, 2002, 08:37 AM   #5 (permalink)
Da91NX
Guest
Posts: n/a
i have the same problem. After my car has sat for over 6 hours when it is below 30 my car won't turn over. I have changed everything. Will the coolant temp sensor not make it start? Maybe i will go pick one up and try.
Old Dec 10th, 2002, 11:39 AM   #6 (permalink)
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
hmm..a couple of weeks ago my car had a similar problem. but i live in az and it doesnt get that cold. i went to start the car and nothing, nothing at all. i figured it was a dead battery and would jump it. i hook up the jumper wires to my friends jeep and try it out. i try to turn the car over and still nothing at all. took the voltmeter to the main fuse box in the engine compartment and it read 14.7 volts on the main power cable. i disconnected the jumper wires and pop the cell covers on the battery. i had one completely dry cell. i figured that it prevented or impeded the current from the jeeps battery to my car. i went and bought a new battery and it started right up.
so, just try ur charged battery by itself.
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Dec 10th, 2002, 12:20 PM   #7 (permalink)
Da91NX
Guest
Posts: n/a
Re: Re: Help! Nissan Sentra won't start!
Where abouts is this, the chilton's manual gives a bad diagram of where it is. They say to drain the coolant so i figures it would be where coolant flows. The only thig i can think of is the sensor right below the VTC selenoid. Is that the one there?
Old Dec 10th, 2002, 01:02 PM   #8 (permalink)
Your electrical friend
toolapcfan's Avatar
The coolant temp sensor is just to the left of the #1 intake runner. It screws down into the top of the lower half of the intake manifold. If you know where the fuel pressure regulator is, look just behind that.
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
toolapcfan is offline   Reply With Quote
Old Dec 10th, 2002, 01:57 PM   #9 (permalink)
Da91NX
Guest
Posts: n/a
that is where i thought it was.
Old Dec 10th, 2002, 08:18 PM   #10 (permalink)
No Nissan Yet
SRV1's Avatar
before you replace it, do a resistance check on the old one in the cold weather. i dont have the specs, but if you test it and have the specs, then you wont have to buy a coolant sensor. Possible distributor problem also.
90 LX Hatch and a bunch of Toyota trucks.
SRV1 is offline   Reply With Quote
Old Dec 10th, 2002, 10:11 PM   #11 (permalink)
OK, I'll try replacing the coolant sensor.
The car started after adding another couple gallons of higher octane gasoline. Here around Cleveland they switch to 10% to 20% ethanol to lower car emissions. 20% is 40 proof, by the way. I guess it doesn't get too cold in Japan. Or maybe there's a lot of Nissans stuck on top of Mount Fuji.....
Thanks for the tips.
Old Dec 12th, 2002, 02:30 AM   #12 (permalink)
USACI here I come
Binger's Avatar
Send a message via MSN to Binger
wont start
I am having the exact same problem. I spoke to a Mechanic at the dealership in Omaha and he didn't say anything about the coolant temp sensor but he told me to do the trick with the fuel pump fuse. He also told me that the Base Idle may be set to low because that was also a very common problem with the sentras. He said that it only costs about $40 to hook it up and test/correct the problem.
I also change my plugs and wires at the same time. I'm just glad that its nothing serious.
http://www.cardomain.com/memberpage/423794/1
When a grisly killing spree in Vancouver left 15 women dead, PETA tried to purchase full-page ads in local papers suggesting that this carnage was no worse than the killing of animals for food.
Binger is offline   Reply With Quote
Old Dec 12th, 2002, 02:08 PM   #13 (permalink)
Traitor
Honest Bob's Avatar
Send a message via AIM to Honest Bob
My car just did that this morning! Its been cold here for a while, but today it kinda warmed up. Never did it before to my knowledge.
RIP 1994 Nissan Sentra LE
1998 Nissan Sentra XE - Sold
1992 Nissan Sentra SE-R - Sold
2005 Subaru WRX Sport Wagon
Honest Bob is offline   Reply With Quote
Old Dec 13th, 2002, 12:06 PM   #14 (permalink)
Send a message via AIM to Sherb
It could be as simple as old engine oil specially if you haven't change this in a while. If this happens in the winter, try running 5W30. When the oil is too thick from cold, oldness, or high weight > 10W30, you will have starting problems. You will also know this if the car has no problem starting when the car is warmed up. Just another suggestion.
1995 Sentra with a few mods
Sherb is offline   Reply With Quote
Old Dec 13th, 2002, 12:51 PM   #15 (permalink)
Da91NX
Guest
Posts: n/a
i just changed my oil like a month ago. I rum Mobil 1 5w-30.
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
