94 Sentra fuel filter - Nissan Forum
post #1 of 7 Old Sep 16th, 2005, 01:50 PM Thread Starter
i think i need to replace the fuel filter. the car starts and then dies like it is starving for gas. where is the fuel filter, is it easy to replace? any other ideas where i can troubleshoot it at? the car has 234,000 miles on it..been a great car...
kelly boy is offline
post #2 of 7 Old Sep 16th, 2005, 02:07 PM
The fuel filter is on a clip next to the master cylinder. You'll need to depresurize the fuel system (take fuel pump fuse out, start the car untill it dies then turn it over 4-5 times to make sure there's no gas left). Then you need to remove the filter from the clip, remove a couple of bolts holding the fuel lines in, remove the lines, hook them up to the new filter, tighten the bolts, mount it on the clip and you're done (takes about 15 minutes). I'ts really important that you connect the line that goes to the fuel injectors to the "out" outlet and the one coming from the fuel pump to the "in" inlet (on the filter) and also have a spare t-shirt or rags to soak up any gas that might spill when removing the old filter.
Be gentle I´m a newbie
lfd75 is offline
post #3 of 7 Old Sep 16th, 2005, 02:07 PM
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
very easy to replace, should near the fire wall.. when was the last time you did a tune up. you might also want to do new plugs, wires, cap, and rotor along with that fuel filter.
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline
post #4 of 7 Old Sep 16th, 2005, 02:26 PM Thread Starter
94 sentra
i replaced all of that...i gave the car to my daughter after i did that...hoping like hell it is not the fuel pump. where is the fuel pump located? is it easy to accomplish?
post #5 of 7 Old Sep 16th, 2005, 03:14 PM
i pwn your mom
psuLemon's Avatar
http://www.nissanforums.com/showthread.php?t=97788
go to that post, its the b13 factory service manual. I dont know where the fuel pump is to be honest. but i know they are a little more work, but aren't too hard to replace.
psuLemon is offline
post #6 of 7 Old Sep 16th, 2005, 04:24 PM
Nissan Addict
greenbean699's Avatar
The fuel pump is located in the tank. You have 2 optinions on replacing the pump if its the problem
1) Take out the lower porshin of the rear seat, then remove the cover to the pump.(4 10mm bolts)
2) Take the whole gas tank down and change out the pump.
Option 1 is probly the easiest. Hope this helps
'08 Sentra 2.0 S--chrome billet grille
'92 xe---HS CAI, ES Motor Mounts, SE-R swaybars w/poly bushings
'92 240sx- RB25DET swap with Silvia Front Conversion
'94 HardBody- stock for now....
I've always said - beware of the guy with primer on his car!
greenbean699 is offline
post #7 of 7 Old Sep 17th, 2005, 06:50 PM
Send a message via AIM to blackmaxima88
check the injectors. I had to replace one a few months back.
option 1 is by far the easiest, seeing as how it takes all of 17 seconds to remove the bottom part of the back seat. you'll see two small plastic loops on the back seat near the floor. pull on those plastic loops, and the seat bottom pops right up. there's your fuel pump cover and harness. couldn't be easier.
Dan
blackmaxima88 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
HElp Fuel filter change not going as it should oscarsosa B13 91-94 chassis 12 Feb 8th, 2006 11:41 PM
94 Sentra dying when the clutch pedal is depressed and we slow down Templar GA16DE 1.6L Engine 3 May 6th, 2004 12:10 PM
87 Sentra Fuel Pump Glacophane E/CA-Series & GA16i Engines 8 Apr 21st, 2004 06:13 AM
Hidden fuel filter? Raul B13 91-94 chassis 8 Dec 16th, 2002 11:19 AM
Fuel filter for 92 sentra jchacon100 GA16DE 1.6L Engine 9 Sep 30th, 2002 08:53 PM
You may post new threads
You may post replies
BB code is On
