replacing ignition switch - Nissan Forum
post #1 of 6 Old Sep 8th, 2005, 01:37 AM Thread Starter
i have to turn the key all the way multiple times just to get the starter to turn over...im pretty sure my ignition switch needs replacing because i replaced my starter, battery, and alternator already...i looked at the ignition switch and i see no bolts to remove it and i dont wanna have to pry it off.... anyone can give me advice on this?...i thought about a remote starter already but not sure if it will work...will it?????
primerblack200sx is offline
post #2 of 6 Old Sep 8th, 2005, 02:57 AM
sno
**best avatar award**
sno's Avatar
haynes or chiltons, BUY ONE!
sno is offline
post #3 of 6 Old Sep 8th, 2005, 06:10 AM
Ditto that.
SOunds like you dont need the tumbler assy correct?The ignition switch is a piece that screws to the back of the tumbler assy, but you will see that in YOUR manual.
ALSET is offline
post #4 of 6 Old Sep 8th, 2005, 02:50 PM
TwiztidKidd
Twiz's Avatar
The two bolts that keep the ignition switch attached to the steering wheel column are riveted so they have to be drilled out. YES, you can install a remote start in your car if it's automatic. It's not recommended in cars with manual trans but it could be done. Even with a remote start you'll still need your key to unlock the steering wheel. Most likely you have an airbag so you want to be extra careful when you work around the steering wheel column. I'd start by taking apart the shifter console and see if there's any kind of spring caught in the mechanism... before you change your ignition switch. You can always clean and rebuild your switch and put it back in.
Twiz is offline
post #5 of 6 Old Sep 8th, 2005, 03:18 PM
The ignition switch(part with electrical contacts) is seperate from the tumbler assy.(part that you put the key in and turn)
Depending on the size of your hands it is a relativly simple procedure.
1st take off the stearing colum shroud . locate the tumbler assy , at the rear of it will be a plastic piece with a wire harness pluged into it( usaully white). This is the ignition switch.That is usaully the culprit given the symptoms you are describing .They cost around 30-60 bucks
There will be two small screws 180 deg. apart that should be visable after unpluging the harness. Then its just a matter of R&R.It is nice to have an assortment of screwdrivers with various lengths .
Hope this helps
Good luck!
Before you do this have you put a volt meter on your stater switch wire and made sure that its not the selonoid ?
ALSET is offline
post #6 of 6 Old Jul 26th, 2016, 10:29 AM
Registered User
Hope this helps
Good luck!
I have to replace mine on a 2003 Pathfinder.
It cranks but at times won't start.
If you are cranking and the lights on your dash go out you have a bad ignition switch.
They should stay on while starting or cranking.
Ernie Perez is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
need to replace Ignition switch. couple questions. Navin R Johnson A32 1995-1999 Chassis 2 Mar 22nd, 2009 12:30 PM
Part # 4 Electrical part of ignition switch Zehrfox Truck & SUV 6 Feb 18th, 2005 08:02 AM
more new toys arriving each day :) Jasper Audio 15 Jan 10th, 2005 05:19 AM
97 Hardbody ignition switch questions andulong Truck & SUV 1 Nov 18th, 2004 12:26 AM
Ignition Switch Problem 1997XETruck Truck & SUV 4 Mar 26th, 2003 10:54 PM
You may post new threads
You may post replies
BB code is On
