» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Old Dec 3rd, 2002, 12:07 PM   #1 (permalink)
sprayin200sx
Send a message via AIM to sprayin200sx
Post does anyone know how to install msd blaster ignition box?
i was wondering how to install the box with the internal coil. i am stuck because of this so i was wondering how to install. there is 4 wires. ground which goes to the chassis, 12 volt switched (found that), trigger got that and the coil negative wire which i cannot find.
sprayin200sx is offline   Reply With Quote
Old Dec 3rd, 2002, 11:51 PM   #2 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
www.msdignition.com
do u have a 6series ignition box. there is an entire pdf installation manual on the website. if i remember right, the negative coil wire is green.
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Dec 4th, 2002, 06:42 AM   #3 (permalink)
NissanTuner
Banned
Send a message via ICQ to NissanTuner Send a message via AIM to NissanTuner
I read somewhere on MSD's site about cars with internal coils needing to fabricate a distributor cap in order to use their ignition systems. Basically all you do is bypass the cars stock internal coil and wire in the MSD ignition system via the fabricated distributor cap. it was an easy mod, probably wouldnt even cost 10 bucks to do. Weed around through their site for info.
NissanTuner is offline   Reply With Quote
Old Dec 5th, 2002, 12:45 PM   #4 (permalink)
sunnysentra
Nissan Addict
sunnysentra's Avatar
I would take that damn thing back. You are wasting your money, it does nothing for GA's. Save that money you earned and save for an ECU. Advancing the timing is better than the MSD. They tick and blow out the coils. Don't ever use it with nology hotwires either because it shorts them out. The stock coil is high energy, I tried many of the coils out there cncluding crane, MSD, nology pro-fire and more, and found the stock coil is best. Don't mess with it, get some magnecores for wires and use NGK plugs, play wtih the head and cams, ECU and throttle body and internal work and maybe the pullies and bolt on header and intake.
Chris 92 classic
sunnysentra is offline   Reply With Quote
Old Jul 22nd, 2003, 02:23 PM   #5 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
does anyone have an MSD or Crane system running with a stock internal coil? How comparable is the stock coil to the MSD or Crane Coils?
05 Frontier SE CC 4x4 (6spd)
