Originally Posted by AznVirus
Anyone know what the stock manual fans for the b14 pulls in cfm?
Ok this is what I did and found out.
1) my airflow meter only goes to 800 fpm. It is also old and not expected to be accuarate.
2) the air flow is from 2.5 to 6.5 inches from the center of the fan approx
I got over 800 fpm for all this distance. It went to 800 fpm easily so it is quite a bit higher than 800.
Assuming 1000 fpm and 13 inch diameter where measured not fan size, with 5 inch diameter dead spot ignoring the bracing and any obstructions I get an answer of 800 CFM.
