Old Aug 8th, 2005, 10:20 PM   #1 (permalink)
rfc_lockhart
Send a message via Yahoo to rfc_lockhart
Tach problems
My thch has been going crazy lately when my engine is not warm. then again it does when it is warm at times to. I can rev to limiter but it dosent kick in and the tach is reading like 8000 at only 4200 then on the next shift range it will be fine. I have checked the tps and various other sensors. I am gonna get a 96 ecu soon (car is a 97) so that is my last hope. I have done the clutch twice in the past year as i broke the first pressure plate into 3 pieces! I checked and rechecked and the problem is not there nor do I have any slipping. I'm stumpped!!
rfc_lockhart is offline   Reply With Quote
Old Aug 8th, 2005, 10:30 PM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Have you ever taken apart the gear stack? If the speedo ring gear is damaged that can play havoc with the speedo...
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Aug 8th, 2005, 10:37 PM   #3 (permalink)
rfc_lockhart
Talking the speedo is good
my speedo works great ive checked it with my truck and it is notch for notch but the damn tach is messin up but i guess it is worth checking out cause i have had a nasty grin or two into second during a race. by the way wes what is the best opt for intake when i do the hot shots turbo kit
Old Aug 8th, 2005, 10:48 PM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
You won't need an intake anymore Do some reading on how turbo kits work and you will see what I mean...
JWT
www.notnser.com
Old Aug 8th, 2005, 10:59 PM   #5 (permalink)
rfc_lockhart
sorry ,I meant manifold
don't i feel sheepish i meant intake manifold. what is the least restrictive or should i just have stock one honed.
tach swap problems lovnyj B14 95-99 chassis 4 May 9th, 2005 10:37 PM
TACH PROBLEMS BIGPAPPA B13 91-94 chassis 5 Sep 9th, 2004 03:01 PM
New wiring problems concerning my tach cluster swap... MomoB12 B11/B12/KN13 82-90 chassis 3 Dec 26th, 2003 02:41 PM
Tach problems 88CHMPNGLD200 B13 91-94 chassis 4 Jan 9th, 2003 09:27 AM
tach problems antdagreat B11/B12/KN13 82-90 chassis 8 Nov 29th, 2002 06:20 PM
