Old Aug 7th, 2005, 08:32 PM   #1 (permalink)
fftom
Another overheating problem
New to the site but probably the same old overheating question. The past two weeks my temperature gauge will almost reach high after traveling on the freeway for about twenty to thirty minutes. The tempertaure will be fine when on the freeway, but when I stop at a light it will climb until I start moving again. Short trips of 15-20 miles are no problem; the gauge reads in the middle. Also, the water in the reservoir is boiling after driving short or long distances, even when the temperature gauge is in the middle. The water pump was replaced two years ago. Any suggestions on where to start?
fftom is offline   Reply With Quote
Old Aug 7th, 2005, 08:52 PM   #2 (permalink)
thestunts200sx
Nissan Addict
drain and flush your radiator...and add water wetter...check to see when your fans come on....
TheStunts200sx
People that owe me money and/are SCAMS::
R1autodesignwholesale
thestunts200sx is offline   Reply With Quote
Old Aug 8th, 2005, 12:10 PM   #3 (permalink)
velardejose
E16T
velardejose's Avatar
Water temp fan switch? Relay?
SPL = knowledge + open mind
velardejose is offline   Reply With Quote
Old Aug 23rd, 2005, 11:49 PM   #4 (permalink)
vikingjam
Sounds like it might be a bad thermostat.
vikingjam is offline   Reply With Quote
Old Aug 24th, 2005, 07:33 AM   #5 (permalink)
ALSET
Also check your radiator cap
ALSET is offline   Reply With Quote
Old Aug 27th, 2005, 12:51 AM   #6 (permalink)
himilefrontier
265k miles and counting..
himilefrontier's Avatar
Send a message via AIM to himilefrontier
Could be a bad thermostat or excessive refrigerant in the A/C system which will cause too much head pressure resulting in excess heat in the condenser.
1998 Nissan Frontier XE/2wd/5spd 1 owner, 264k miles
1985 Olds Cutlass, 350 Chevy, owned for 14 years
WANTED: 1968-1973 Datsun 510 or 1991-1994 Sentra SE-R
http://www.myspace.com/junkyardengineer
himilefrontier is offline   Reply With Quote
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
Overheating problem.. What should I do next? alkon GA16DE 1.6L Engine 4 Jan 25th, 2005 10:05 PM
2000 Nissan Sentra Overheating Problem? Metallion QG18 1.8L Engine 3 Jan 24th, 2005 04:37 PM
Overheating b13fury SR-Series Engines (DE/VE) 5 Mar 19th, 2004 03:54 PM
Hi all, I'm new here. Got a problem with my B14, pls help. Mayonaise B14 95-99 chassis 8 May 12th, 2003 06:03 AM
