can someone explain to me where the idle adjust screw is?, i really need to find it but can't. my haynes manual doesnt even have a good description of it
Do you know where the throttle body on the intake manifold is? If so, got the the opposite side of the intake manifold (passenger side), and that is the IACV. On the IACV in front is the idle screw.
__________________ 1991 Sentra SE - Auto to Manual swap, 15" Rota Subzero's, 205/50 Kuhmo 712's, Tsuru headlight conversion, SE-R front and rear disc brakes, SE-R front and rear swaybars, SE-R throttle body, SE-R rear inner taillights, HS CAI and Header, H&R springs, Koni shortened struts, ES Hyperflex kit, B&M Short Shifter, Autometer gauges.
