Old Jul 31st, 2005, 07:29 PM   #1 (permalink)
snoop
fuckin Chalkaraka
snoop's Avatar
engine rebiuld
I wanna take my ga16 motor and bore it and stick performance parts in it. What parts would i be looking to put in and what would need to be done to it to get the most power?
snoop is offline   Reply With Quote
Old Jul 31st, 2005, 08:51 PM   #2 (permalink)
thestunts200sx
Nissan Addict
check www.sentra.net
all the info is there...as well....search before asking...cause all this info is readily available at the above mentioned site as well as www.nissanperformancemag.com with their project 1.6L
TheStunts200sx
People that owe me money and/are SCAMS::
R1autodesignwholesale
thestunts200sx is offline   Reply With Quote
Old Jul 31st, 2005, 08:56 PM   #3 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
you can't really bore our motor, the walls are very thin and you can only do it to lieka 1.7 or 1.69 which you would need custom pistons and rods, you are better off gettina new motor
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline   Reply With Quote
Old Aug 1st, 2005, 04:17 AM   #4 (permalink)
Nissan300ZXZ31Turbo
Nissan Fanatic
You can do some easy upgrades to a GA16DE to bring the horsepower to about 125ish... well, that is what I got when I did these things (I have a '95 GA16 so results might be different with a '91-'94 GA16): Unorthodox crank pulley, slightly advanced timing, bored exhaust manifold, cold-air intake system, and some good spark plugs and spark plug wires. Depending on the model vehicle your GA16 is in, those simple upgrades can result in some ample acceleration increases. If you have a B13 or B14 Sentra or 200SX, results might vary slightly due to I have a '90 Sentra B12 with the GA16DE in it. For more drastic results, you can get JWT performance camshafts, JWT performance ECU, port & polished cylinder head (must do yourself), performance headers, KA24 fuel pump, KA24 fuel injectors, bored intake manifold... well, the list goes on. Needless to say, you can pull some ample power out of a GA16, though most will say just swap for an SR20.
Nissan300ZXZ31Turbo is offline   Reply With Quote
Old Aug 1st, 2005, 06:19 AM   #5 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
a few things, do you have a dyno for those numbers, cuz a ga that has been fully done up, (hs header, hs cai, jwt cam, jwt ecu, port and polish, 2" exhaust, ur pulley, extrue honed IM) was only 132whp, you were prolly look more around 105whp. secondly, you dont need nor would you want the ka24 fuel pump or the ka24 inectors, they will server you no purpose.. the kid is better off gettin another ga and turboeing it or like you said doin an sr20 swap if he wants to be like everyone else
How to Clean Your Engine Nismo1997 Car Care 21 Jun 2nd, 2008 05:29 PM
Engine Knock on Mexican built GA16DE Sentras Pablo14 GA16DE 1.6L Engine 44 Jul 5th, 2006 10:16 PM
engine check light is on archer98 GA16DE 1.6L Engine 7 Jun 6th, 2004 10:52 AM
Bad Gas Mileage 1997XETruck Truck & SUV 48 Sep 5th, 2003 02:35 PM
SR20DE - internal engine problem after head decking signat New Member Forum 1 Aug 4th, 2003 10:58 AM
