Originally Posted by wes
Your mistaken... Anyway again I ask why? The car runs OK no? It is not hesitating or down on power? If so why the total analization of everything? I appreciate wanting to know the car, but seriously everything sounds totally fine.
The cat is designed to do exactly what it is doing, if the cat was totally melted there would be other symptoms and it would throw a CEL sooner or later because the rear O2 would not receive the correct signal.
well it actually isnt running OK. there are a fair number of things that dont seem to be right. as for the total analization of everything, i contribiute that to this: I live in the middle of nowhere and this car is my life. I work 30 miles away from here(1.25 hour drive) and there is NO public transportation, well except from the end of may to the end of july, and still thats only twice a day. i drive this car around 60-80 miles a day and if somthing happens to it im fucked, ive put everything i have into it, and until im done paying off some (other)bills i have no money to save. Gas alone is fucking killing me, i put about $25 every 2 days.... thats like $350 a month or somthing. Once again
i have NO money to pay someone to fix/diagnose this car. hence that constant questions, im trying to learn about this car, so i can do all the repairs myself, if it needs them. If i seem paranoid.... trust me i am. i
CAN NOT have anything happen to this car. i hope you understand.... o ya its a 96 200sx Se w/ A/T, A/C, power everything, no aftermarket mods, and 134,XXX miles
With that said....
I really have no idea what is up. i have a couple guesses, but really im clueless. ive done everything i know, and it still is having problems.
If you can, please help..... here are the symptons. i know there is more than 1 problem causing these things, so
ANY ideas are helpful.
1.rattles along with little clicks over bumps, but not speed bumps. seems that if both wheels(eather both front or both back) hit bumps no sound. if one does then it makes a rattleing/high pitched clicking(sorry thats the best i can do to describe it) noise.
2.steering feels "loose"
3.it seems to turn easier to the right side
3(a). just had the wheels aligned, but it still pulls rights unless im taking turns fairly quick, then it seems to change the side it pulls to.
3(b). front passenger wheel squeeks, only after the car has been drivin a while, and if i hit a bump some times it stops
3(c) during acceleration from a stop, the wheel rocks left to right(unless im holding it)
4.sometimes there is a vibration from the rear(i think). this is strange, because it seems to vibrate the whole car.
5.if i put it in neutral and rool backward the shit to reverse, there is a loud pop/click in the front end
6.seems to hit bumps very hard, but struts/shocks were just changed
7.at idle there is a loud hissing noise from the rear of the car, as well as the intake
8.brand new yokomo(sp?) 50,000 tires and worn down on the outer edges. i bought them about 6,000 miles/ 2.5 months ago. they're on the front and were put on because i was pulling into the parking lot at work, going about 15-20 MPH, and hit the front right tire on the curb and it popped, goodyear said it was too thin to repair.
9.breaks make a groaning noise when stopping, not the whole time, but only right before i come to a complete stop.
10. sometimes there is a lot of somke soming out the tail pipe, sometimes there is NONE. these happen at weird times too, sometimes it smokes after ive been driving like 1 hour and it sits at idle, sometimes it somkes when i start the car. but the strange thing is that when i start the car in the morning there is NO SMOKE coming out of the tail pipe. also when its not smoking, the sound from the exhaust sounds like the exhaust is Hallow/echoing, and is not very strong. when smoke is coming out, it sounds deeper like it is emminating from the tip of the exhaust, as opposed to somewhere inside the pipe, and it is also alot stronger.
11.Excessive gas consumtion.
12. at idle i hear a low rumble from the steering wheel, but it stops it i move the steering wheel at all(push it up/down, left/right, or in/out, not turn it)
13. somthing(injectors?) under the hood is making a VERY loud clicking noise.
14. after driving for a while if i pull the engine oil dipstick out smoke starts to rise from the tube(engine off)
thats all i can think of thats wrong with this car. but if i think of more i will post later.
here is a list of things ive done and how long ago they were done. *note - all this was done by me or my friend and I
-changed front brakes/rotors ~ 2 months
-changed struts/shocks ~ 2 weeks
-replaced PCV ~ 2 months
-changed air filter X2 ~ 1st time ~2.5 months /2nd time~4 days
-changed spark plugs X2 ~ 1st~bosch plats~2 months /2nd~NGK~3 weeks, were changed b/c boschs were white on electrode, and black on the threads
-checked MAF
-used auto diagnoise mode II to monitor fuel/air mixture, at idel CEL was flashing on/off at irregular intervals indicating toor lean/too rich respectivly, accerleration would show rich, and deceleration would show lean, i dont know if this is normal or not...
-check o2 sensor
-replaced o2 sensor~earlier today
-changed plugs/cap/rotor
-tightend throttle cable(no ot too much)
-checked all hoses, with the following results: leak is PS(resvior to pump) hose, not big however, leak in ATF cooler hose(not large, fluid level has not moved but it is greasy around it and after driving it is shiny)
-readjusted rear drums.
-adjusted idle to 800rpms in 'N', drops to ~700 in 'D' or 'R'
-listen to each injector pulse
- pulled plug wires 1 at a time, car stumbles on each one being pulled.
-Checked CV boots
-checked belt tension
-checked egr, with car off i was able to push it up, but it was a little hard
-checked and tightened/greased ALL suspension parts(control arm/strut to knuckle connector/tie rod/sway bar/ lateral link etc)
im tired of typing but there is more if you can help with any of this, PLEASE do im begging you.
thanks
EDIT: forgot to add i also(using the FSM) reset the fuel/air mixture learning data, first through the MAF, then through the o2 sensor. the MAF reset did make a difference but it went away the next day(back to normal)
