Go Back   NissanForums.com :: Nissan Forum > Technical > Forced Induction & Nitrous Oxide
Forced Induction & Nitrous Oxide Turbocharger, supercharger, and nitrous oxide information
Old Jun 27th, 2005, 05:05 PM   #1 (permalink)
blakeZX
Send a message via AIM to blakeZX
Question Intercooler Installation Help?
Hello-
Just looking for some good advice on how to go about installing an intercooler (stock part out of a Mitsubishi Starion) in my 1984 300ZX Turbo 5spd. The individual I purchased it from had it installed into a 1986 Turbo, so hopefully minimal cutting (if any) to fit it will be required. I was wondering if anyone out there had any experience in putting intercoolers into Z31's, any year? I am pretty sure my A/C accumlulator/dryer is gone, because there is no belt coming out of my A/C Compressor, it's just a bare spindle. I don't know what this thing is supposed to look like, but I'm pretty sure it normally goes behind the engine fan, which is where the intercooler should mount.
Here is a picture:
The guy I got it from told me that all he did was remove his A/C compressor unit to make it fit. I can handle that, but once that is done, where do I go from there? What kind of piping will I need to put in place? Forgive me for being new to this, but I really need some advice here. I have a couple pics of the intercooler, too:
Any help or links to guides would be super and I would love you for all eternity and then some.
Thanks,
-Blake
-Blake S.
blakesherman@gmail.com
1984 300ZX Turbo Coupe 5spd
blakeZX is offline   Reply With Quote
Old Jun 27th, 2005, 05:29 PM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
I don't see how that piping setup suits your car. Look at your engine bay, the throttle body is on the right side, whereas the intercooler inlet and outlet are on the left hand side, unless the intercooler is flipped updise down it doesn't make sense. Even then I think it would hang extremely low to the ground. You will need to order a bunch of piping bends in the proper diameter and then cut them to route the piping where you need it to go.
Honestly it sounds like you haven't done this before so I would do some research and figure out how others have fabbed IC piping on your car. Heck you can look at IC piping from any car and it should help you figure things out.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Jun 27th, 2005, 08:57 PM   #3 (permalink)
blakeZX
Couldn't it just be that I have to turn it around so it's facing the opposite way? That way the piping remains at the same height but the inlet/outlet would be in the right side, by the intake/turbo/T.B.
Am I right?
-Blake S.
Old Jun 27th, 2005, 09:50 PM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
Am I right?
Without seeing it in person it is hard to say, but think about what you just said. One of the inlets/outlets would be facing the wrong direction as in it would face towards the front of the car and you would have to route it back around to get to the TB....
JWT
www.notnser.com
Old Jun 28th, 2005, 01:50 PM   #5 (permalink)
blakeZX
That's true, I had missed that. Anyhow, I did some research and it turns out that this core is apparently not worth my trouble to put in, so I'll be getting rid of it and trying to get a hold of a MKIV supra cooler instead. Thanks for your help though, wes.
-Blake S.
Old Jun 28th, 2005, 07:07 PM   #6 (permalink)
wes
Wise Cracker
wes's Avatar
Here's an idea, cut off the existing outlets leaving only as much pipe as you need to make it work, mount it upside down and you should be in business. Honestly it will require just as much work to make another core work as you have to make piping anyway...
JWT
www.notnser.com
Old Jul 14th, 2005, 01:46 AM   #7 (permalink)
Marc Z31
Nissan Fanatic
Marc Z31's Avatar
Send a message via AIM to Marc Z31
Here is what I did when I had a MKIV intercooler.
Piping- http://img.photobucket.com/albums/v3...6-0698_IMG.jpg
http://img.photobucket.com/albums/v3...6-0695_IMG.jpg
http://img.photobucket.com/albums/v3...6-0694_IMG.jpg
http://img.photobucket.com/albums/v3...6-0693_IMG.jpg
http://img.photobucket.com/albums/v3...6-0637_IMG.jpg
http://img.photobucket.com/albums/v3...6-0634_IMG.jpg
The black 90 degree rubber coupling is from a volvo 850 turbo. The turbo itself was a bit bigger than stock.
Have you thought about chemical intercooling? Alcohol injection would save you about $200 on intercooling with an air/air. I would swear by it. Keep the charge piping short, use a 5-10 psi pressure switch to kick on the alcohol. Anything past about 13psi on stock turbo is a waste. You are just blowing hot air at that point.
...BUILT FOR THE HUMAN RACE...
Marc Z31 is offline   Reply With Quote
Help with Omnifi MP3 installation Slavisa Audio 0 Mar 4th, 2005 08:57 PM
Reducer hoses on intercooler & Stock size almera_n15_1999 Forced Induction & Nitrous Oxide 4 May 4th, 2004 08:32 PM
Intercooler Gb Jump On It While It's Here! XsjadoTwin11 Group Buys 3 Mar 23rd, 2004 02:42 PM
Intercooler Ruth'Less Forced Induction & Nitrous Oxide 2 Jul 18th, 2002 08:56 PM
