Go Back   NissanForums.com :: Nissan Forum > Technical > Forced Induction & Nitrous Oxide
Forced Induction & Nitrous Oxide Turbocharger, supercharger, and nitrous oxide information
Old Nov 19th, 2002, 12:48 AM   #1 (permalink)
200sx se-r-t
Posts: n/a
Exclamation fuel management!!!!!
hello all.. i am in the process of turbocharging my 200sx se-r i now have a s14BB turbo and a stock det manifold... both portmatched.. i have a 3 " exhause some 500cc injectors and a cobra mass air meeter.. i am considering an alternitive to fuel management than the jim wolf.. i have a few friends who are great tuners and could tune a fuel computer such as stand alone or AFC... i my self dont see the point of spending 500 on a computer i alredy have and then every time i upgrade a part i have to send it in for 2 weeks and get it re programed spending another 200 for that.. so i am goign to go with the AFC for now... the only question i have is when i upgrade teh MAF it is going to send diffrent voltage signals to my ECU will the AFC be able to use that diffrent MAF eventhough it is sending diffrent voltages.. also the injectors i have are not msd's or nissans.. will they work with the AFC and finaly if tuned properly will teh AFC work for fuel management...
thanks for any help i can get
justin
Old Nov 19th, 2002, 12:56 PM   #2 (permalink)
cranium
Nissan Fanatic
cranium's Avatar
Send a message via AIM to cranium
do you currently have the AFC? i was going to run a haltech on mine and at that point you are completely seperated from the stock ecu and you make adjustment though a laptop. or there is SDS that is roughly the same but doesn't require a laptop, it has its own programer and is only marginaly cheaper.
cranium
When push comes to shove, my car is uglier than yours.:)
cranium is offline   Reply With Quote
Old Nov 19th, 2002, 01:59 PM   #3 (permalink)
200sx se-r-t
Posts: n/a
yes currently have the AFC i was also considering the haltech.. wich will probly come in the future.. i am looking to push 300hp wiht the SAFC anything above that i will then go to the haltech due to price diffrence i am looking to go with the AFC for now.. but i would like to upgrad the injectors mass air and fuel pump with the afc i just want to know if it is possible
thanks for the help
justin
Old Nov 20th, 2002, 10:26 AM   #4 (permalink)
tredragon
Send a message via AIM to tredragon
I believe it is possible, don't know about reliability, but check out Emanage too. And please... let us know how it goes.
Tre
RR SR20DE
tredragon is offline   Reply With Quote
Old Nov 20th, 2002, 11:43 AM   #5 (permalink)
morepower2
Icy Hot Stunta
morepower2's Avatar
Re: fuel management!!!!!
justin
Forget AFC's and the twiddle boxes, you end up fighting the ECU's self learning loop and get inconsistant running. The AFC does not have enough leeway to tune for a bigger MAF and way bigger injectors. The ECU will probably go into limp home mode when trying to compensate for injectors much bigger than 440cc, at least in my experiance. What 500cc injectors are you talking about? No one makes 500cc injectors unless you are talking modified RC injectors.
If you want a stand alone, get an AEM ECU, a lot of capabilty and very easy to tune with a great user interface.
Unless you are good at ECU tuning and have access to a true horiba or Motec broad band 5 wire sensor A/F meter, it is best to stick with a JWT ECU.
Mike
There can only be one Icy Hot Stunta, Don't Hate.
Master of Level 9
morepower2 is offline   Reply With Quote
Old Nov 20th, 2002, 02:02 PM   #6 (permalink)
200sx se-r-t
Posts: n/a
my goal here was to keep cost down.. if i had endless funds i would get a haltech... the jim wollf to me is a joke.. why spend 500 to get the ecu programed.. then wehn i change injectors or MAF i have to send it back in and have down time on my car.. i just dont like that idea at all.. by the time i had the damn thing bought and tuned once or twice i could have bought my standalone by then... and had 10 times more control as well as the freedom to tune it when evey and on the fly... as far as the injectors they are toyota mr2 injectors they came out of a turbo charged mr2 from i dont know what year... if the ecu wont handle it... here comes for m y second question.. what if i am shooting to use 370cc injectors from a 300Z and keep the stock MAf until i decide to run more power... the next upgrade i do will include the haltech.. as well as a larger turbo... if needed as i said i am runnig a s14 turbo it should be pretty good as far as boost goes... thanks for any help i might get
Old Nov 20th, 2002, 02:06 PM   #7 (permalink)
200sx se-r-t
Posts: n/a
ok boys AEM doesnt make theyr computer for Nissan....
Old Nov 20th, 2002, 02:19 PM   #8 (permalink)
200sx se-r-t
Posts: n/a
i just checked out the e manage.. it seems like a good system any thoughts?
Old Nov 20th, 2002, 04:26 PM   #9 (permalink)
psshhgoesmysr20
You get what you pay for.
psshhgoesmysr20's Avatar
Send a message via AIM to psshhgoesmysr20
Doesn't AEM have a universal unit? I am using the AFC currently in cunjunction with a BB ECU. I plan on seeing how much power I can get out of it consistantly before I switch to something else. A friend of Mine John Huh's turbo spider made 395 Hp AFC tuned in the SCC shootout for 400 hp cars, and was voted the most consistant of the 4, which included Shaggys turbo 200.
psshhgoesmysr20 is offline   Reply With Quote
Old Nov 20th, 2002, 04:33 PM   #10 (permalink)
200sx se-r-t
Posts: n/a
not sure.. i went to aem's web page and looked at applications.. i dindt see any universal ones in there.. i dont think there is becaues it is a plug and play ecu replacement... as far as the afc goes... i want to chang the MAF and Ijectors so it may make a diffrence on how well it will work
Old Nov 20th, 2002, 05:55 PM   #11 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
aem makes their system for everything. i beleive it is compatible w/most every car...just they don't make wiring harnesses for some vehicles and they will have to make one for you or something like that. jwt isnt a joke though...they are very good at what they do as the mike that posted above can vouch for. i do however share your thought on if i am going to spend $500+ to get my ecu reprogrammed and have to keep sending it off, why not just buy a system that replaces the whole ecu.
Katana200sx is offline   Reply With Quote
Old Nov 20th, 2002, 08:07 PM   #12 (permalink)
SuckiT
Send a message via AIM to SuckiT
Aem universal system hasnt been released yet. They have updated there software which includes Autotune now tho. This enables those with a W/B O2 to punch in the desired a/f ratio... and the ecu tunes for it. Check this thread out http://www.honda-tech.com/zerothread?id=316594&page=1
Or another option is getting the W/B O2 and a e-manage. Use the extra slot for the 2nd maf to datalog the O2 while driving for real time feed back and cross reference the voltage to the rpm. That obviously is for safety not power. Tuning for power is on a dyno.
SuckiT is offline   Reply With Quote
Old Nov 21st, 2002, 01:01 AM   #13 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
JWT=plug&play...u can make a lot of reliable power very easily.
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Nov 21st, 2002, 01:46 AM   #14 (permalink)
Zak91SE-R
Posts: n/a
JWT's ECU is far and away the best plug and play solution. You will never get your car to run as well with a standalone system as it will with a JWT ECU.
As far as 370cc injectors and a stock MAF - 250 HP is the max HP you'll be able to run. Both the MAF and the injectors will be completely maxed out at that point.
Old Nov 21st, 2002, 01:50 AM   #15 (permalink)
morepower2
Icy Hot Stunta
morepower2's Avatar
An AFC can compensate for 370cc injectors ok but has proablems with larger ones. Don't get a haltech, they are one of the worst stand alones out there. Haltec, PMS suck. A Tech 3 is pretty good for the money, it has a nice interface, fairly easy to program.
An S14 turbo is pretty small on the exhaust side although it has a ball bearing center section. A GTI-R turbo is the best cheap turbo to bolt onto a SR20.
Mike
Master of Level 9
