Help...boost problems(Kinda long)
Hi there guys!
I hope you can help me with my GtiR swap into my B13(formerlyGA16De).
I tried searching but all I get is different topics and I can’t seem to pin out the right problem and solution.
First let me tell you what I got.
I have a GtiR SR20DET swapped in a B13. I got the GtiR as a front clip so everything is as is, all that I needed was a engine mount and the axles/driveshafts of a Sr20DE.I am using the stock DET ECU(hopefully it is the stock DET ECU, I will explain why I say this later)
Problem:
My car pulls hard but when it reaches 4,500rpm the boost starts to die off suddenly with a sputter. (The wires are okay, cap, and distributor. I am using a 4G63T (EVO III) fuel pump, converted to fit the car, at stock boost. I have used the stock NGK plugs, NGK platinum plugs and cross referenced Denso Iridium plugs)
-could there be a boost leak or something? I checked everything and it seems fine.
However, I decided to disconnect my TMIC and just plug my air filter to the TB, so it would be like I am running NA. when doing this the car pulls fine all through out the rpm band.
Could it be that the ECU I have is from a SR20DE and not a DET? But the stock Sr20De ECU can still run a turboed engine, right? I am kind of new to this stuff so please bear with me. One other thing is that the car does seem to go rich at idle since I kinda smell unburnt gas, I thought the injectors had a leak but there’s none.
Everything is stock besides a crush bent 3 inch exhaust system all the way, downpipe all the way to muffler....
Thanx,
DAXX
