O2 sensor in Blue bird DET *help
Okay, recently i've hooked up an autometer AF gauge. My car still has the original 1.6l engine harness in it which requires just a single wire o2 sensor to the ecu. Now, for those of you that have a Blue bird motor, what O2 sensor are you running, and where did you get it. I require a non heated o2. I can't find one that fits. I've tried the 1.6L o2, i've tried other various 2.0L o2's. I can't find one that fits! They are all too small or too big with the adapter in the manifold. The o2 adapter on the manifold can be taken off with a 32mm socket. Either way i go, with the adapter on, or off, I can't get an o2 to fit. The o2 that was in the motor was heated, and i can't run that. I've already tried. I hooked it up to ground and a constant 12v charge, and nothin doin. It still doesn't read. I've checked, and re-checked all the wires for continuity, and its all fine like that. The meter has power and reads 1 bar rich. It never climbs. Hopefully i'll figure it out before anyone responds, but that is unlikely. Any help is appreciated. thanks.
R.H.D s13-->T04E RB20DET
Wangan Stylez Super Stars Team
