Go Back   NissanForums.com :: Nissan Forum > Technical > Forced Induction & Nitrous Oxide
Forced Induction & Nitrous Oxide Turbocharger, supercharger, and nitrous oxide information
Old Oct 2nd, 2002, 11:38 PM   #1 (permalink)
87Truck
Question VG30 Turbo engine specs?
I have 2 VG30 engines one is dual cam 4 valve with one turbo and the other is a single cam 2 valve engine with one turbo. What I need to know is the compression ratios for these engines. The SOHC engine I am considering installing it in my 87 Truck with the trucks induction system. and I dont know if the turbo engines compression is lower than the engine that is already in the truck which is a VG30E SOHC. The dual cam engine I will probably sell as it looks too complex of a swap. Thank you in advance.
87Truck is offline   Reply With Quote
Old Oct 3rd, 2002, 10:39 PM   #2 (permalink)
Nismo Skyline
Nismo Skyline's Avatar
The SOCH engine has either a 7.8 or 8.0 compression ratio. The 7.8 was 1984-86 and the 87-88 had the higher ratio.
The DOCH motor would be a real pain to install in that application. You will find that the SOCH turbo interfere's with the frame rail. You will probably have to modify the manifold to make it fit.
"It doesn't weigh zero" Dan Barnes
"The trouble with the world is the Stupid are cocksure and the Intelligent full of doubt" Bertrand Russell
"Racing is life, everthing before or after is just waiting" Steve McQueen
Nismo Skyline is offline   Reply With Quote
VG30 specs Michael Chutny A32 1995-1999 Chassis 4 Apr 25th, 2004 06:28 PM
JDM ca18de(non turbo) specs vs USDM ca18de spec? WMengineering B11/B12/KN13 82-90 chassis 29 Aug 19th, 2003 02:42 AM
Looking for an RB20 Turbo engine for a 1995 Altima GXE Elmoisgod U13 1993-1997 Altima 9 Jul 15th, 2003 10:57 AM
engine swap or turbo for 2002 Sentra GXE? ckykm QG18 1.8L Engine 6 May 18th, 2003 01:32 AM
Source for turbo specs & maps for U12 nevz73 Forced Induction & Nitrous Oxide 0 Aug 3rd, 2002 06:33 AM
