Go Back   NissanForums.com :: Nissan Forum > Technical > Forced Induction & Nitrous Oxide
Forced Induction & Nitrous Oxide Turbocharger, supercharger, and nitrous oxide information
Old Jul 6th, 2004, 03:39 PM   #1 (permalink)
Tia
Terrano 2.7 TDi power loss (not MAF!)
Hi,
New member looking for some help.
My 1999 Terrano is suffering from power loss under acceleration and struggles up an incline. The MIL is not on.
I have endured MAF sensor failure (80k miles) and fuel pump failure (110k miles), and the power loss is not as bad as either of these faults, but rather just very sluggish. It still manages to reach 80+ mph on the level, but takes forever to get there.
Since the problem started, I have done a complete filter change and cleaned the mesh filter in front of the MAF sensor, but this has made no difference.
Does anybody have any ideas for me to have a look at, as I can't really afford another expensive garage bill!
Cheers for any help.
Tia is offline   Reply With Quote
Old Jul 6th, 2004, 03:52 PM   #2 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
glow plugs (it's diesel right?) exhaust leak possibly? maybe some bad fuel?
My Website, check it out!
Old Jul 6th, 2004, 03:55 PM   #3 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
maybe injectors clogged?
05 Frontier SE CC 4x4 (6spd)
Old Jul 6th, 2004, 04:12 PM   #4 (permalink)
chimmike
chimmike's Avatar
they have direct injection, which, iirc, doesn't have injectors........
Old Jul 6th, 2004, 04:13 PM   #5 (permalink)
Tia
Yeah, it's a diesel, but starts on the first swing. If it was the glow plugs, would it not battle to start? The entire exhaust is only a year old, but I have not checked that yet.
The problem started a couple of weeks ago, and I have refueled a few times since - if it was dodgy fuel would it not have cleared the system by now?
Forgot to mention in the earlier post that it has a very slight hiccup at about 2500rpm when revving while stationary, with a slight puff of smoke.
Old Jul 6th, 2004, 04:14 PM   #6 (permalink)
chimmike
chimmike's Avatar
could be an exhaust leak or a turbo problem...............a bad glow plug doesn't necessarily mean it won't start either.
Old Jul 6th, 2004, 04:14 PM   #7 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
damn hippie technology...
maybe I misunderstand what TDI is... I thought it injects the fuel into the combustion chamber at the exact moment of compression, which in a diesel is a lot higher, and this causes combustion no?
Old Jul 9th, 2004, 08:38 AM   #8 (permalink)
Tia
What are the chances of this problem being either a faulty exhaust gas recirculating valve or a stuck turbo waste gate? Any ideas would be appreciated.
Old Jul 28th, 2005, 04:27 PM   #9 (permalink)
rmills
Me too
Hi
I have a 1997 Ford Maverick with exactly thesame problem, including the hiccup at 2500 rpm. Could someone explain the other problems thatcould cause this? (ie the ones Tia has solved previusly).
rmills is offline   Reply With Quote
Old Aug 1st, 2005, 03:31 PM   #10 (permalink)
rmills
Solved
Hi
I fixed my problem this weekedn-the problem was a dirty air flow meter (which I cleaned) and the car now (literally) runs like new. It had got dirty because there was a gap in the air filter/flange assembly letting in dirty air.
Old Aug 28th, 2007, 08:16 AM   #11 (permalink)
doglaterrano
doglaterrano's Avatar
Send a message via MSN to doglaterrano
Talking
I'm from Suriname (that's in South America) and I own a '99 Terrano diesel (TD27ETi).
I also have that problem with mine; when I rev up from idle it stutters for a moment and shoots to max after blowing some xtra smoke from the back. Did you ever fix your problem?
I just joined so sorry for the late late reply
doglaterrano is offline   Reply With Quote
Old Sep 1st, 2007, 12:47 PM   #12 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
Send a message via AIM to Zen31ZR
Depends on the ambient temperature. Glow plugs are only used during the start cycle, when the engine is cold and the fuel needs help with ignition. Its basically a version of a gas engine choke. Glow plugs are not used during normal operation. And in fact if the glow plug circuit is malfunctioning and does come on during normal engine operation it can cause severe engine damage due to fuel pre-ignition.
1992 Yamaha FZR 1000. 145 Hp, all stock..
Zen31ZR is offline   Reply With Quote
Old Sep 3rd, 2007, 09:01 AM   #13 (permalink)
doglaterrano
Ok, and if these "hickups" at 2000 rpm occur even if the weather is normal (around 30 degrees celcius) and the engine is at normal operating temp, is it still normal? Or is there a malfunction somewhere.
Old Sep 23rd, 2008, 08:14 AM   #14 (permalink)
sparkybg
I have exactly the same behavior. I am sure my glow plugs are in perfect order. All filters and the oil changed.
I suspect MAF sensor, but I cannot be sure. It is expensive. 400Euros in my country, so I must be sure before I go and buy it.
Anyone? PLEASE?
Edit: How to clean MAF (air flow) sensor? Did you use some king of solvent or something, or just air? Or something else?
sparkybg is offline   Reply With Quote
Old Sep 28th, 2008, 09:24 AM   #15 (permalink)
sparkybg
Just changed the MAF sensor. Everything is perfect now.
power loss at high revs UnderDog GA16DE 1.6L Engine 4 Jan 20th, 2006 01:37 PM
intake help power loss IronSurfer General Discussion 7 Apr 4th, 2003 08:45 PM
Help! Power loss and hesitation! gb95ser B14 95-99 chassis 6 Apr 4th, 2003 03:42 PM
Sounds like a diesel and power loss. sentrastud B11/B12/KN13 82-90 chassis 8 Jan 9th, 2003 07:51 AM
power loss Russellc GA16DE 1.6L Engine 8 Jun 21st, 2002 08:23 PM
