ok...im putting my 370's in my ga16, cause im in the process of turboing it...anyhow, i have the upper intake plenum off, and i have 1 injecotr in...problem is is that all the screws dont want to come out, and im begonning to strip them.(the screws that hold the injecotr in- the 2 tiny ones)...if i strip it, ill be screwed of course...has anyone else had a problem with this, and what the hell did you do to get them out?
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
take a hammer and chisel and slightly rap the side of each of the screws a few times... nothing hard just a good solid jolt. that should loosen them up, if not do it again...
don't believe me? Ask Deric, AznVirus, helped him out putting the 370cc injectors in a new fuel rail the other day.
When my brother and I were removing the stock injectors, we ran into the same problems. What we did was one of us used some needle-nosed pliers to rotate the screw while the other used the philips screwdriver. They all came out fine that way.
A reallly nice #2 phillips bit works really well too. I used some liquid wrench type loosening spray, let it penetrate for a few mins. Put the rail in a vice and they came out no problem. If you even slip the bit a little bit you will want to replace the philips screws.
