Go Back   NissanForums.com :: Nissan Forum > Technical > Forced Induction & Nitrous Oxide
Forced Induction & Nitrous Oxide Turbocharger, supercharger, and nitrous oxide information
Old Jan 22nd, 2004, 01:04 AM   #16 (permalink)
Harris
Super-Mod with a 240
Harris's Avatar
Send a message via AIM to Harris
I see. Now that's something new to me actually. I was always under the impression that any amount of water in the cylinders would eventually cause hydrolock/damage to the motor. Could you please explain exactly what you mean by little water? Are we talking about water in liquid form or just the relative moisture in the air?
"The greatest trick the devil ever pulled was convincing the world he didn't exist".
-The Usual Suspects
Harris is offline   Reply With Quote
Old Jan 22nd, 2004, 07:54 PM   #17 (permalink)
SE-RtinMI
Send a message via AIM to SE-RtinMI
A small ratio of water in the fuel slows the combustion. Abnormal amounts start to wash down the cylinders then you get hydrolock.
97200sx
SE-RtinMI is offline   Reply With Quote
Old Jan 23rd, 2004, 02:59 AM   #18 (permalink)
morepower2
Icy Hot Stunta
morepower2's Avatar
read this
http://www.se-r.net/about/200sx/scc/...injection.html
Mike
There can only be one Icy Hot Stunta, Don't Hate.
Master of Level 9
morepower2 is offline   Reply With Quote
Old Jan 23rd, 2004, 03:24 AM   #19 (permalink)
myoung
NPM Lead Editor/Webmaster
myoung's Avatar
Originally Posted by morepower2
Couple more:
http://www.nissanperformancemag.com/.../project200sx/
http://www.nissanperformancemag.com/...aaronmay02.php
http://www.nissanperformancemag.com/january04/300zx/
myoung is offline   Reply With Quote
Old Mar 5th, 2004, 01:21 AM   #20 (permalink)
rollo
OK. I understand that water injection helps lower the air-fuel charge temperature to prevent detonation.
How about if I only cool down the fuel before mixing it with the air?
Would that also help prevent detonation & probably reduce the fuel octane requirement?
rollo is offline   Reply With Quote
Old Mar 5th, 2004, 01:45 AM   #21 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
VERY VERY VERY small amount... the difference being the fuel temperature is immediately shot up to the point of combustion so why bother cooling it... the air is the part of the mixture you're concerned about because you know that the combustion of the fuel is going to release X amount of energy as heat anyways.
05 Frontier SE CC 4x4 (6spd)
Old Mar 5th, 2004, 02:29 AM   #22 (permalink)
rollo
I was thinking that the chilled fuel would also help to cool down the air as they mix, and that would help create a denser & cooler air-fuel charge prior to combustion. Of course, the fuel will release heat energy during combustion, but if the air-fuel charge temperature was initially lower, wouldn't the peak combustion temperature would also be lower for the same amount of heat energy released?
Old Mar 5th, 2004, 11:32 AM   #23 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
How cold are you planning on chilling this air? YOu planning on freezing it? Like I said before it will help a little bit but never as much as nitrous, propane or any liquid-gas reaction.... you freeze the line and you freeze the gas... so how cold can you get it? And remember the ratio of air to gas 14:1!! The air has anywhere from 12-16 times the amount of fuel... think this through yourself...
Old Mar 7th, 2004, 06:22 AM   #24 (permalink)
rollo
The thought here is to cool the fuel to probably 10 degrees below the ambient temperature and reduce the chances of detonation.
Old Mar 11th, 2004, 11:05 AM   #25 (permalink)
Stephen Max
Like James said, you've got anywhere from 11-13 lbs of air for every lb of fuel, so cooling the fuel is not going to be anywhere near as effective as cooling the air. Cooling the fuel only 10 degrees below ambient won't even have a noticeable effect, I would guess.
Stephen Max is offline   Reply With Quote
Old Mar 13th, 2004, 01:39 AM   #26 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
sometime "keeping it simple" is the best route to go. a well built air to air core will work very well on the street and is much less hassle than an air to water setup.
here's a buddy of mines car. civic, ls-vtec, 60-1 turbo, 20*8*3 extruded core FMIC, 2.5 in. IC piping. this graph was at about 17psi on a 105 deg day @ around 2:00pm in AZ. you can see the "heat soak" effect as the car idles, then how quickly the charge temp drops as flow across the FMIC increases
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Mar 13th, 2004, 02:20 AM   #27 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
here's a little data from my car. b13, DET, FR T3/T67 turbo (T04R compresser wheel), 20*11*3 garrett extruded core anodized black, bumper covers almost 1/2 of the FMIC this graph was at about 17psi WOT on a mid 70's deg night/morning at 3:30AM here in AZ. i dont have my wheel speed sensor hooked up yet, but this graph represents the data while boosting 3rd and 4th gear WOT in the middle of the desert with no traffic around. you can see that the charge temp drops as soon as i start accelerating or boosting
www.full-race.com
866.FullRace
Old Mar 22nd, 2004, 06:36 AM   #28 (permalink)
rollo
Smile
My primary concern is to prevent detonation without needing to use costlier high octane fuels. Just thinking that cooling the fuel would do it.
I believe water injection got its start during the era of piston engined airplanes in the 1940s (mostly during World War 2) where it was used to help avoid detonation at higher boost pressures for that short spurt of power. These aero piston engines (with forced induction of course) were already intercooled (they used to call it aftercooling) but wasn't enough to prevent detonation at higher boost levels. So, it does look like that water injection was originally meant to help complement intercooling.
Old Mar 22nd, 2004, 10:58 AM   #29 (permalink)
Chuck
Drifting is for amatures
Chuck's Avatar
Send a message via AIM to Chuck Send a message via MSN to Chuck Send a message via Yahoo to Chuck
yeah, now that ive done more research, I have to wonder, would watercooling almost be a "cheap way" to get the effects of higher octane gas, without having to pay the extra 20c a gallon
Chuck is offline   Reply With Quote
Old Mar 22nd, 2004, 11:03 AM   #30 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
If you're concern is that water injection would do much better than trying to chill the fuel. The latent heat of vaporization of water is very high and does much more for cooling the intake charge than fuel.
Removal of very stubborn broken water pump bolt. Varn Z31 300ZX(T) 1 Feb 11th, 2004 03:12 PM
1978 280Z - broken water pump bolt, now what Varn Z31 300ZX(T) 1 Jan 6th, 2004 05:33 PM
drove over lots of high water...should i be worried? ]\[ /-\ ]\/[ Houston Nissan Enthusiasts 16 Nov 24th, 2003 11:38 AM
S13 water pump thecollector S13 240SX 1989-1994 3 Nov 22nd, 2003 03:56 AM
Aquamist 1S Water Injection Units 1fastser Group Buys 0 Jun 14th, 2003 07:15 PM
