No.
I'm assuming you have the motor on a stand? I believe my numbers were stamped just inside the block on one of the ends. The five number sequence is for the main caps (1-5) and the four number sequence is for the rods (1-4).
For your bearing sizes you add the numbers from the block to the numbers from the crank. (i.e. If the numbers on the block were 22222 2222, then your bearing sizes would be 44534 for mains and 3324 for rods).
Also, make sure you keep everything in order...don't mix up your caps! Scribe the respective number on them if it's not already done. #1 starts at the front cover.
Hope this helps....Jody
*very close*
http://www.imagestation.com/album/?id=4290960821
