the cheapest way to run a turbo system on a n/a car is with an (fmu) it rises the fuel pressure depending on boost so that the engine has more fuel with the boost,and running the stock computer,fot this you will need a walbro255 fuel pump due to the high system pressure. this is good for a 5-7 psi turbo system. , the oil line must be tee'd at the oil pressure switch,and return line welded or bolted to the oil pan at a high point.
check out my ride :) http://members.cardomain.com/ga16deturbo
by ing the topic.. or if you are so to be inclined to learn, take off the ecu cover, behind your sterio, next to your pedals, to the right of the gas pedal.. there is yoru ecu.. there is a flathead screw on the side, turn it right one full turn, then wait 5 sec. then turn it all the way back left 1 turn.. its reset. (i dont htink your car shoudl be on.. im not sure)
fmu is used on NA/nitrous/turbo apps. so technically.. yes, it would work.. it will work as long as you have a +/- ..... but, will it be effective.. if you can tune it, hell yea
the FMU is a fuel pressure riser it raises the fuel pressure 10 psi for every 1 psi of boost , so... no , it does not work for an N/A car and does not work for nitrous either,its for boost,and its made by VORTECH ,the supercharger co. it costs about 170.00 and you need a highflow fuel pump like the walbro 255 for those high pressures, also you can only run 8psi max as the fuel pressure at that boost is 117psi and the injectors can possibly lock up at 120psi. , hope that helps
i reset the ecu simply by disconecting the battery for more than 10 min. the ecu memory goes into learing mode once the power is back on , its not needed but i just did it.
