Ok i know there is another thread going with a similair question but i needed advice spcifically related to my car/engine.
so...
My SR20DET is currently out for a rebuild. I am going to get a custom equal length manifold made up for my new turbo, which brings me to the qustion of, What turbo is best for me???
My SR20:
On its way:
40thou overbore
Custom Forged Pistons - Cryo Treated and HPC Coated
GTiR Conrods - Shot peened, Cryo Treated and HPC Coated
Standard Crank - but will also be Cryo Treated for extra strength
Standard Bluebird DET Head, Cams, etc - ported and poilished
Block will be O Ringed & im probly going for a copper Head Gasket
Custom Intake Manifold and Plenum - if i have the funds
Bosch Ignition Module (to be controlled by the Wolf)
Multi Coil Ignition Packs (to run off Bosch Module)
Bosch Motorsport Fuel Pump
Rising Rate Fuel Pressure Regulator
What i already got:
Custom Fuel Rail
550cc Injectors
700mm x 300mm x 80mm Front Mount Intercooler
Wolf 3D v.4 Engine Management System
Standard Bluebird Exhaust Manifold
T28 Turbo - ported and polished exhaust housing
Imported NISMO Heavy Duty Engine Mounts
etc, etc... to much to list.
What "Specific" turbo would be best suited to this build. i need something thats going to spool up relatively quick but also be able to suck every last KW i can out of my engine! While staying in its efficiency range.
Also I will be trying to push some really stupid boost into this engine, any advice or experience in how much something like this could hold from a T3/T04e? Is 30 PSI just stupid? I wont be reving past the 7500RPM point unless i get forged rods, crank, and do my head... oh yeah and win the lotto!
Appreciate your opinions/suggestions/racial slurs
Riste.
Pulsar SSS with U13 Bluebird SR20DET
Custom Fuel Rail with 550cc Injectors
T28 Turbo Ported and Polished
FMIC, 3inch Exhaust System, NISMO Engine Mounts
etc... STAGE 2 Coming Soon :)
Pictures Of Little Rocket
