fuel pump problem
ok.. recently i had an issue. i finally got my timing, idle. set perfectly.. thanks to wes... the wideband o2 from innovate motorsports is working perfectly. my autometer a/f guage now works accurately. but recently my fuel pump has been making a wierd noise.. well its not a different noise.. its the same noise only louder then normal.. the 255 walboro lp pump is loud as it is.. but the humming sound is louder. two days ago the fuel line from the fuel rail to the regulator. came apart from the earls fitting and i was leaking fuel. i fixed that and today the pump started making the noise.. car still runs.. fuel pressure seems to drop a lil though. my question is it the pump which is only 2 years old.. or could it be a clogged fuel filter? or line?.... i am not using a stock fuel filter.. i am using an earls inline fuel filter which is easy to take out.. and i believe its reusable... any info please let me know
GA16DET: Hotshot Turbo Kit, JWT Cams and Ecu, Cobra MAF, JGY Fuel Rail, 50LB Injectors, JWT Clutch, Koyo Radiator, Turbo Xs Bov.
