Go Back   NissanForums.com :: Nissan Forum > Technical > Forced Induction & Nitrous Oxide
Forced Induction & Nitrous Oxide Turbocharger, supercharger, and nitrous oxide information
Old Aug 18th, 2006, 06:44 AM   #1 (permalink)
nissanlucino
GA15 Turbo power
nissanlucino's Avatar
Send a message via AIM to nissanlucino Send a message via Yahoo to nissanlucino
problem after problem after problem......
Hi after fixing another problem, another problem has given me trouble. I was on the road and when I arrived home the tempreture rose up like hell!!! When I went to open the hood, The fan melted!!! The high tempeture from the turbo caused this!!!!!!!!!!! Now I searched and I coulden't find these slim fans for the sentra. Does anybody know where I can buy these?
Thanks
Jason
I've got a B14 with a 1.5 engine.
It's also a turbo!
nissanlucino is offline   Reply With Quote
Old Aug 20th, 2006, 12:21 PM   #2 (permalink)
nissanlucino
GA15 Turbo power
Exclamation
I bought the slim fans no problem there. Installed them. The engine still heats up like a bitch!!! I checked the radiator and if the coolent is flowing well. Everything OK there. This happens to me when I shift on high revs it heats up too too much. When I drive normally, everything is OK. I was thinking of getting a bigger radiator. Any help/opinions guys??
Also sombody told me that the slim fans arent ok because they have so much blades . Anybody know if it's true?
Jason
It's also a turbo!
Old Aug 20th, 2006, 12:35 PM   #3 (permalink)
dmroberson
Nissan Fanatic
dmroberson's Avatar
Send a message via AIM to dmroberson Send a message via MSN to dmroberson Send a message via Yahoo to dmroberson
Well, personally, I don't have turbo, yet. But it's my understanding that the number of blades does not determine the effeciency of the fan. What you look for, is the amount of air that it moves, in CFM (cubic feet, per minute). That determines the efficiency of the fan.
Da's Wha's Up...
04 Sentra 1.8S Radium AT -- Weapon-R Secret Weapon Intake w/Cold Air Box and Ram Air Kit, clearmask.com 3m paint protection film, Bi-xenon HID headlights, 35% window tint, Custom ground wires, HKS Sport cat-back exhaust, Greddy Air Diversion Panel -- TRADED :(
06.5 350Z Silverstone Base 6MT -- Weapon-R Engine Torque Damper, 35% window tint, clearmask.com 3m paint protection film, Fujita F5 Short Ram Intake, Air Diversion Panel, Titek Carbon Fiber Intake Duct (painted), Nismo Titanium Shift Knob, Nissan OEM Drilled Aluminum pedals, Motordyne 5/16" ISO Thermal Plenum Spacer, Motordyne MREV2 Manifold, Pioneer AVIC-D2 Multimedia Navigation System, Pioneer ND-BC2 Universal Rearview Camera.
dmroberson is offline   Reply With Quote
Old Aug 21st, 2006, 10:12 AM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Jason
Do the fans work? Are they wired correctly so that the air is flowing the proper direction? Do the fans run and not shut off and the car still heats up?
You really should get a coolant temp gauge. This wil give you more accurate inormation than the stock gauge. I can watch the temp. move more than 20 degrees and the stock gauge stays in the same spot...
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Aug 21st, 2006, 11:44 AM   #5 (permalink)
nissanlucino
GA15 Turbo power
Hi Wes
The fans work fine. They are flowing in the right direction. They start to rotate when the engine warms up like they usually do acting in the same way like the OEM ones. I was thinking of getting a thicker radiator so that the radiator can keep up with the engine. I am still running a stock radiator Wes. Also before, I wasnt shifting at high revs. Now since I fixed my other problem I drove the car hard shifting on high revs on first second third and fourth. I think it's the radiator. (my personal opinion)
Thanks
Jason
It's also a turbo!
Old Aug 21st, 2006, 11:55 AM   #6 (permalink)
wes
Wise Cracker
wes's Avatar
My question is how hot does it get? Does the gauge hit the top? If so when it does is the coolant in the overflow tank boiling?
Are you experiencing this while just driving around or do you have to be boosintg for this to happen?
I wouldn't start throwing money around just yet. If the car is moving and air is flowing through the radiator it should not be overheating unless you are boosting it non-stop for 10+ minutes. I have a few ideas.
1. Air in the cooling system. Make sure you re-bleed the cooling system per the FSM before you try anything else.
2. If that does not work I would drain, check the t-stat, refill per the FSM.
3. If that does not work I would do a compression test and check for a leaking head gasket.
JWT
www.notnser.com
Old Aug 21st, 2006, 01:48 PM   #7 (permalink)
nissanlucino
GA15 Turbo power
I am having this problem when when I dirve almost to the redline on every gear. When I drive around normally, it heats up normally; a little bit more than the middle the heat gauge marks. If I drive around hard too much, the gauge alomst hits to the very top. When this happens, the coolent in the overflow tank boils.
It's also a turbo!
Old Aug 21st, 2006, 02:06 PM   #8 (permalink)
wes
Wise Cracker
wes's Avatar
I see. Follow my suggestions above.
JWT
www.notnser.com
2004 & 2005 Armada brake problem Shannonop Titan & Armada 11 Aug 5th, 2007 03:33 PM
1995 altima gxe problem acg1304 U13 1993-1997 Altima 4 Jun 10th, 2005 02:08 PM
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 10:59 PM
Sentra vibrations and other problem premk71 B15 2000-2006 8 May 13th, 2005 08:09 AM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 09:18 AM
