Wastegate
It sounds like you have the opposite problem. I was under the impression that if your wastegate opens it bypasses the excess boost and releases it. If you are experiencing a spike, than your wastegate isnt opening correctly, like stuck shut then pressure builds over the set limit than your blow off valve pops (or emergency relief valve). What your deal sounds like is at five lbs your b.o.v. or wastegate is coming open or set wrong releasing the pressure. If you are spiking, you may have blown a gasket or something, releasing pressure.
but then again, maybe im all wrong
