Hi guys,
I bring this subject up with trepidation, as it seems to be a touchy subject to some. Particularly the turbo system I will refer to that nobody here seems to like. I am looking at
this turbo system. It has the small T20 turbo like the E15ET used. I am more interested in quick spooling and improved midrange torque. I am not trying to build an Evo killer.
This is what I am trying to do:
Yes, I am the guy who said that all I wanted was about 40 more h.p. on an older thread about this kit. Let me offer some backround info for my application. I race my 4WD B12 Sentra on ice with unstudded Blizzak winter tires at an average temp of about 15 deg. F. I feel with low boost I would be OK without an intercooler, just like the '80's Nissan turbo cars were [200SX, Pulsar, etc].
I feel I have done my homework and have spent many hours searching all appilcable threads on the subject of turbocharging your GA16DE. Correct me if I'm wrong, but the way I understand it, the factory GA16DE ecu and injectors can't support even 2 or 3 lbs. of boost.
OK, three questions please:
1. I heard the SR20DE injectors [I think they are 240cc] are a direct swap for the original 185cc GA16DE injectors. Is this accurate?
2. Do you think I could up the injector size [to the 240cc injectors] in my '93 GA16DE and use a rising rate fuel pressure regulator and/or an Apexi AFC to tune for just 5 lbs. boost?
3. Would the stock GA16DE ecu have the corrective range to adjust the mixture [with the larger SR20DE injectors] correctly in the normal off boost running [cruising] conditions?
Thanks,
Mike
