Go Back   NissanForums.com :: Nissan Forum > Technical > Forced Induction & Nitrous Oxide
Forced Induction & Nitrous Oxide Turbocharger, supercharger, and nitrous oxide information
Old Aug 13th, 2005, 02:26 PM   #1 (permalink)
velardejose
E16T
velardejose's Avatar
Turbo water cooling helps cool boost air?
Hi
I know water cooling helps extend the turbo life, asuming oil press and volume is adequate
My question is, does it help to cool the compressed intake air?
This particular config has no ic now
Thanks in advance
SPL = knowledge + open mind
velardejose is offline   Reply With Quote
Old Aug 13th, 2005, 02:36 PM   #2 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
http://www.nissanperformancemag.com/.../project200sx/
Originally Posted by npm
Water injection will reduce our air intake temperature and provide a safer level of combustion. It will also lower the temperature in the cylinders, reducing the chance of pre-detonation. This will allow us to increase the boost by several psi to achieve a higher horsepower output
that might help out a little
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline   Reply With Quote
Old Aug 13th, 2005, 04:59 PM   #3 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Originally Posted by psuLemon
I believe he is talking about water cooling the cneter section. The air gets head because it is being compressed. Water cooling the center section will not help with what you are trying to do.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Aug 13th, 2005, 05:47 PM   #4 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
sorry, i should really read the whole thing and try not to mix things up.. sorry for that.
but wouldn't it be smarter to worry bout gettin an intercooler for the turbo to ensure the safety of the motor rather than other little mods
Old Aug 13th, 2005, 09:31 PM   #5 (permalink)
velardejose
E16T
Sorry for my poor english
Wes is right, I am talking about water cooling the center section
I am using this turbo with the oil lines conected only, water lines are not connected
yup, I know this screams 'hot intake air' but the ic must wait til this months paycheck
Thanks a lot
Old Aug 15th, 2005, 11:43 PM   #6 (permalink)
Joel
Pivot 180
Joel's Avatar
To me that screams more like 'bearing failure'
SilviaWA
1992 180SX: cwest, vertex, wise, pivot, gemax, embleton, kyb, blitz, whiteline
Joel is offline   Reply With Quote
Old Aug 16th, 2005, 10:42 AM   #7 (permalink)
velardejose
E16T
Hi
This particular config is based on a stock e16s engine that was turboed using a small toyota ct9 turbo+carb
Thing pushes clean till 4.2 k, then 'runs out of air'
I fear I am pushing this old lil turbo beyond the map's eficiency island, where compressed air temp goes up
Peace
Old Aug 22nd, 2005, 01:16 PM   #8 (permalink)
Blown284
Send a message via AIM to Blown284
Wink
The buick grand national guys have been utilizing water/alky kits for a long time and if you're truly that interested in it, I'd go looking there. Water/alky really works well and yes it cools the discharge down to ambient where you want it. However, it can be very interesting to tune for.
By the way, a lot of the folks are utilizing a 50/50 mix (50% distilled water/50% alcohol).
Regards,
Tim
550+hp S/C Mustang GT
'05 Nissan Titan LE
'05 Nissan Quest SE
Blown284 is offline   Reply With Quote
Old Aug 22nd, 2005, 05:09 PM   #9 (permalink)
bahearn
bitter old man
bahearn's Avatar
The alcohol will require an ECU retune as your mixture will go from rich to pig rich.
Bruce in Houston
bahearn is offline   Reply With Quote
Old Aug 22nd, 2005, 05:21 PM   #10 (permalink)
velardejose
E16T
This is a noob question:
The water, I know what it is for
The alcohol is exclusively for cooling purposes too? Or it gets burned too helping to enrich the mixture?
Thanks in advance
Old Aug 22nd, 2005, 06:36 PM   #11 (permalink)
velardejose
E16T
Works as an antidetonant too, liberating O2 in the process
Cooling comb chamber and exh gases
Interesting...
I thinkl one of the cardinal points in these configs is where to locate the alcohol/water nozzle
Old Aug 22nd, 2005, 08:45 PM   #12 (permalink)
bahearn
bitter old man
bahearn's Avatar
That's the whole point.
Nope. Don't confuse alcohol with nitrous. Alcohol is already partially oxidized, that's why it has considerably fewer BTUs than an equal amount of gasoline.
That's the antidetonant in action.
Bruce in Houston
Turbo for sr20de (Sticky Please) onyxeros Forced Induction & Nitrous Oxide 47 Feb 19th, 2004 12:54 AM
All the joy of a turbo w/o that annoying boost (someone please help me) Ninety-Nine SE-L GA16DE 1.6L Engine 8 Oct 31st, 2003 10:38 AM
Turbo Question- Water line fitting size? t-dog Forced Induction & Nitrous Oxide 2 Jul 3rd, 2003 10:42 AM
Turbo Question Kambrian Forced Induction & Nitrous Oxide 10 May 20th, 2003 03:00 PM
Turbo XS Dual Stage Boost Controllers $172 Shipped Howitt Group Buys 0 Apr 27th, 2003 01:08 PM
