Not sure how to put this question but here goes.
I have taken the engine and "all" the wiring harness out of a 90 model Sentra and put it in an 87 model Sentra. The 87 had a carb. The 90 has TBI. The problem is not getting fuel to spray thru the Injector nozzle. Getting fuel up to Injector but won't spray. Have checked Injector for ohms and it is within specs.
Chilton doesn't give the voltages that are on the Injector plug in on TBI.
Just says check with specs. but none are there in the manual. Knowing the voltage there would help as then I could check it. Have cleaned Injector also.
