Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Jan 21st, 2005, 10:29 AM   #1 (permalink)
Alchemy
Oil and carbon going to air cleaner
3000 km since the rebuild on my e16i
i took off the pipe that runs from the exhaust manifold to the air cleaner, and smoke from burning oil was coming out of it when the car is running. and i get lots of carbon build up in the lil entry way into the air cleaner, under that silver piece. what causes this and how can i fix it? i get no sut or anything out the back of the exhaust system.
Alchemy is offline   Reply With Quote
Old Jan 21st, 2005, 12:28 PM   #2 (permalink)
BeEleven
just rattle can it
BeEleven's Avatar
Send a message via AIM to BeEleven
that's exhaust gas being passively recirculated into the air cleaner to be burned again. it's part of the emissions control system. there should be a small filter where the gas enters the cleaner. if this is dirty, you can replace it, or remove it alltogether and just plug the hole in the exhaust. there's no way to keep the engine from producing some carbon byproducts, but if it's burning a lot of oil, thats another problem entirely.
Why did I pick such a slow car?
1986 B11 Sentra with cRucial modz
BeEleven is offline   Reply With Quote
Old Jan 21st, 2005, 03:01 PM   #3 (permalink)
Alchemy
yeah i mean its burning more oil than it should be through there.
Old Jan 22nd, 2005, 12:06 PM   #4 (permalink)
Gsolo
Post Freak
Gsolo's Avatar
Send a message via MSN to Gsolo Send a message via Yahoo to Gsolo
maybe if that filter is so clogged up that it backs up the exhaust somewhat causing oil to get by the valve ??? just a thought.
Student at UTI Avondale
2nd place SkillsUSA/VICA WA State Automotive Maintenence '04
had an 87 pulsar...still planning CA20DET
1970 Chevy BelAir 350V8 300hp...soon to get M21
Gsolo is offline   Reply With Quote
Old Jan 23rd, 2005, 04:05 PM   #5 (permalink)
Alchemy
air filter is fairly clean
Old Jan 23rd, 2005, 04:17 PM   #6 (permalink)
mille-16i
Nissan Junkie
mille-16i's Avatar
Check the oil and see if it is still clean looking only 3000km since rebuild it should look near new if it dose not maybe you have a blow by problem. Run a compression check to ensure the cylinders are good and check the PVC system if it is clogged it will over pressurize the engine causing oil to escape.
Mille's ride Check out My B12 SportCoupe
There's no such thing as a soul. It's just something they made up to scare kids, like the boogeyman or Michael Jackson. -Bart Simpson.
mille-16i is offline   Reply With Quote
Old Jan 24th, 2005, 06:32 PM   #7 (permalink)
Alchemy
which parts of the pcv system could be clogged? ive already replaced the pcv valve. but theres a lil oil in the pcv line that runs from the top right side of the valve cover when ur facing the engine :S . how many lines are in the pcv system. i only know of the one that runs from top of valve cover down to the pcv valve.
Old Jan 24th, 2005, 07:05 PM   #8 (permalink)
Slacky
Post Freak
Send a message via AIM to Slacky
all about the custom ram air couda hood, i got 2 hoods all i need is a mig welder i think a ram air tunnel to the efi on a ga16i would work pretty good, how about u, o yea and i had a real bad oil burn with my e16i but the filter was always good so thats ruled out and i didnt have the greatest blow by either
Slacky is offline   Reply With Quote
Old Jan 24th, 2005, 10:30 PM   #9 (permalink)
BII
Viva el iPod
BII's Avatar
Send a message via AIM to BII Send a message via MSN to BII Send a message via Yahoo to BII
This sounds like the AIV to me, I removed it in my car, sionce I'm running a weber and there is no provision for this.
Is downshifting cheating? Decide for yourself.
Originally Posted by Scott
Because you were ****ing annoying. You were the neopet of your day.
BII is offline   Reply With Quote
Old Jan 25th, 2005, 06:18 PM   #10 (permalink)
Alchemy
wheres the AIV?
Old Jan 25th, 2005, 11:37 PM   #11 (permalink)
BII
Viva el iPod
BII's Avatar
It a tube on the drivers side that goes from the exhaust to the air cleaner.
Old Jan 26th, 2005, 06:23 PM   #12 (permalink)
Alchemy
thats the one i was saying in the first post that had lots of burning oil coming through it when the car is running. the metal tube from exhaust to air cleaner housing
Changing Oil types ace B13 91-94 chassis 18 May 6th, 2006 10:10 PM
CRAZY CARBON redneck truck Naturally Aspirated 6 Dec 18th, 2004 02:50 PM
synthetic oil superv General Discussion 59 Sep 1st, 2004 10:40 AM
'94 Sentra, 1.6L w/ several Issues. :) Caj Darkmoon GA16DE 1.6L Engine 16 Jun 9th, 2004 05:31 AM
read this out ! Crazy-Mart E/CA-Series & GA16i Engines 4 Nov 18th, 2002 03:25 PM
