Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Jan 15th, 2005, 11:38 AM   #1 (permalink)
cmack
cmack's Avatar
Exclamation help!.. coolant air lock
as the title says i'm having some trouble geting the heat pumpin in my 87 b12. first it was the theromstat changed it then it was good but about a week later the upper rad hose blew out and now i have a massive air lock in my cooling system causing my heat to either suck of actually blow cold (and today its -35°c) so that doesn't help me to much.... i've done some searching but none of the threads that i found explained how to actually bleed the cooling system on a e16 engine (carb) any input would be greatly appriciated thanks in advance
cmack is offline   Reply With Quote
Old Jan 15th, 2005, 02:03 PM   #2 (permalink)
Crazy-Mart
Kick ass 1.5L / Mod
Crazy-Mart's Avatar
Send a message via ICQ to Crazy-Mart Send a message via MSN to Crazy-Mart Send a message via Yahoo to Crazy-Mart
simple solution here ... park the car with the front end higher ... to get the rad cap over the height of the thermostat... (at worst jack the front end)... get that rad cap off, run the engine till it get up to temp while filling it till no bubble come out anymore.
Make sure you put the heater totaly to the hot, and fan working full also, this will help get rid of the air that might have got into the heating system also. this takes about 5 minute to do.
Crazy !
Sentra Sport Coupe 87 Turbo
14.850@97.454mph
H&R Spring, 15psi, TMIC, 370cc, Nismo mount and pulley, Almasi tuned ecu...
Crazy-Mart is offline   Reply With Quote
Old Jan 16th, 2005, 10:29 AM   #3 (permalink)
Gsolo
Post Freak
Gsolo's Avatar
Send a message via MSN to Gsolo Send a message via Yahoo to Gsolo
i was just going to add....i lived up a hill somewhat....so whenever i messed with cooling systems (regardless of what car) I'd drive around town until the thermostat would open up then when i come back just take my time going up the hill, all the air would work its way up the radiator...then when i got home i'd relieve coolant pressure(be careful doing that...actually don't do it, i don't want someones 3rd degree burns being my fault ).
Student at UTI Avondale
2nd place SkillsUSA/VICA WA State Automotive Maintenence '04
had an 87 pulsar...still planning CA20DET
1970 Chevy BelAir 350V8 300hp...soon to get M21
Gsolo is offline   Reply With Quote
Old Jan 16th, 2005, 01:19 PM   #4 (permalink)
cmack
cmack's Avatar
thanks for the tips everyone last night i drove around without the rad cap on and it actually got upto normal temp for the first time in a couple days... parked on a hill i'm not sure if it was steep enough or not but i was outside watching bubbles come up for a while went a looked at the temp gauge and it was back down to 1/4 i dunno about that so i topped it up again ran it at about 2-2500rpm took another 5 minutes to get upto temp again then i just got to cold and said screw it.... so its still locked up pretty solid
Old Jan 16th, 2005, 01:23 PM   #5 (permalink)
cmack
cmack's Avatar
i forgot to add i was thinking maybe the new thermostat i put in is locked open because the temp gauge only goes upto 1/4-3/8 but last night without the rad cap on it got upto normal temp i'm guessing thats just because of the air lock
Old Jan 16th, 2005, 01:30 PM   #6 (permalink)
Slacky
Post Freak
Send a message via AIM to Slacky
is it one of those locking t stats?
Slacky is offline   Reply With Quote
Old Jan 16th, 2005, 03:18 PM   #7 (permalink)
Crazy-Mart
Kick ass 1.5L / Mod
Crazy-Mart's Avatar
never put a fail safe into an E-serie engine : trust me !!... your better buying yourself an Oh Henry with the 2$ difference ... that engine will not heat over the 1/4 with a locked thermostat open.
Crazy !
14.850@97.454mph
Old Jan 16th, 2005, 10:28 PM   #8 (permalink)
Gsolo
Post Freak
Gsolo's Avatar
i just wanted to add for anyone who ever runs a search....this can also be a cause of bad gas mileage. Not coming up to temp can cost a few mpg.
Old Jan 17th, 2005, 03:05 AM   #9 (permalink)
cmack
cmack's Avatar
YES I SECOND THAT!!!!!!!!! my gas millage has seriously dropped and it was the same before i changed the thermostat.... after i changed the thermostat it was way better on gas (should've changed the hose too it said nissan on it so i'm guessing its the same age as the car), tomorrow i'm going to a heated garage so that my engine can actually get upto normal temp seeing as how its -30 to -40°c outside i'm sure that isn't helping me very much... hopefully it works out good because no heat+winter= geting a very bad cold
Turbocharger: How does it really work....? asleepz Forced Induction & Nitrous Oxide 102 Jan 10th, 2005 12:25 PM
Painted or polished CAI question? Maxwell31 General Discussion 6 Nov 22nd, 2004 12:15 AM
gas mileage down 3mpg...could it be the MAS? svasica B15 2000-2006 16 Nov 8th, 2004 08:21 PM
yet another blower motor thread Hyunduzu B13 91-94 chassis 6 Jul 20th, 2004 08:18 PM
My Intake Idea.. More Cold Air? sentravis GA16DE 1.6L Engine 9 Nov 10th, 2002 10:43 PM
