Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Dec 9th, 2004, 06:22 PM   #1 (permalink)
Alchemy
help , rebuilt engine stuttering
my e16i engine was rebuilt 2000kms ago and worked fine but now the car stuttrs when u hit the gas and sometimes it sounds like its gunna die mid drive, took it to the dealrship to get it checked out, they found no error codes on the comp. ive replaced the tps , plugs , wires etc.. what could be causing the problem?
Alchemy is offline   Reply With Quote
Old Dec 9th, 2004, 09:16 PM   #2 (permalink)
wintercar
Did you recheck all your grounds? Or maybe loose crankshaft nut?
wintercar is offline   Reply With Quote
Old Dec 9th, 2004, 09:56 PM   #3 (permalink)
recycled_toddler
Moved on...Ciao!
recycled_toddler's Avatar
Unhappy
Check your vacuum hoses and replace as necessary; Make sure that there's no loose hoses, etc. That could help as well.
I have to re-rebuild my E16i Pulsar engine because I screwed up; I took a risk and it blew up in my face...almost. I learned the hard way that you don't use mineral-based oil to break in a Nissan engine. It's fine for aircraft engines, but apparently not for cars; The new Hastings chrome rings didn't seat. It ran serendipitously well from here to Alberta this past summer, but started losing power after returning. I checked and swapped out everything...to no avail. no trouble codes, nothing. New vacuum hoses, rebuilt EGR valve (Yes, it is possible to rebuild 'em!), you name it...nothing.
Today, I ordered up a new Fel-Pro total engine gasket kit, a new set of Perfect Circle rings and new intake valves to match the exhausts I got on eBay--Beck Arnleys. I'll pre-prep one of the two E16 blocks and piston setups I got, build up another 33M head, see if GOJO is willing to part with that cam (Hint-Hint! LOL), swap the crank out of the current engine into the new one and see if I can do it right this time. And this time I'm using CASTROL OIL!!!
I only got 7,000 miles out of this one...*sigh* No one said lessons were free...
I'll keep y'all up to date. Ciao...
Later, taters; Off to a better place. Catch me there!
recycled_toddler is offline   Reply With Quote
Old Dec 9th, 2004, 10:00 PM   #4 (permalink)
Alchemy
wow thats harsh, and i have no vacuum leaks i checked several times and also sprayed the lines with throttle body cleaner while the car was running cause if there was a leak it would bog down the rpms noticably.
Old Dec 10th, 2004, 04:01 PM   #5 (permalink)
recycled_toddler
Moved on...Ciao!
Unhappy
I woke up this morning, got in my Pulsar to fetch some cigs, came back and noticed that there was foamy, tan oil on my parking spot. PANIC: I blew the head gasket. So...drag out an extra crank, get some new main/rod shells, build a new engine ASAP. SH**!
Old Dec 11th, 2004, 12:45 AM   #6 (permalink)
wintercar
That's not good. I wouldn't be happy either...
BTW, why did you rebuild your motor the 1st time? did you have any headwork done last time? or is your head warped?
I had a BMW 318i once and every couple of months a headgasket would let go...
Old Dec 11th, 2004, 05:31 PM   #7 (permalink)
recycled_toddler
Moved on...Ciao!
I rebuilt the motor because it had been neglected and abused by the previous owner; With 125K original miles, power was down and it was burning oil. Considering it's a sports car, I can see that happening...
This failure was my fault, so I'm just gonna do it all over...this time it oughtta work. I figured out what the deal was: A few weeks ago I found that my clicker torque-wrench was sadly out of calibration; It would click before it was supposed to. I used the same wrench to torque the head down. This time, I'm just gonna use the old-school torque wrench. Hasn't failed me yet!
Old Dec 12th, 2004, 05:15 PM   #8 (permalink)
B11sleeper
Datsun Guy
B11sleeper's Avatar
Send a message via AIM to B11sleeper
Originally Posted by recycled_toddler
I learned the hard way that you don't use mineral-based oil to break in a Nissan engine... And this time I'm using CASTROL OIL!!!
What did you use synthetic oil? That isn't good for fresh rebuilds and new engines.
1981 datsun 210. nothing interesting here...
B11sleeper is offline   Reply With Quote
VQ35DE in a S13??? toddk S13 240SX 1989-1994 68 Dec 31st, 2007 10:55 PM
Converting a VG30 engine to Fuel Injection MrBadExample Truck & SUV 1 May 15th, 2004 10:17 AM
New Engine , Same Knocking LUVMYTRUCK Truck & SUV 11 Jun 24th, 2003 01:14 PM
New Engine, Same Knocking LUVMYTRUCK New Member Forum 6 Jun 23rd, 2003 10:49 PM
F1 engine plays a tune Mudge Off Topic 7 Dec 18th, 2002 02:33 AM
