Idle Speed Control Valve??
ok for about a month now ive had some problems. i have an 89 pulsar nx.
i initially thought it was the fuel pump. it would sputter ALOT until the rpm.
three times now it would sputter so bad that it would just shut off. each time after i let it sit for awhile it would start back up. but this time it wouldnt.
each time it died on me when i put the key in the ON position there would be a clicking noise coming from two places. 1. the ISC valve (little round cylinder behind the throttle body with three wires going to it) and 2. the fuse box. the fuse thats clicking is a big gree square one 2nd from the right above the smaller normal fuses.
when those two things are clicking i found the car will not start. i disconnected the harness from the ISC and no clicking, but there is still clicking from the fuse box. and vice versa... when i took the fuse out i still got clicking from the ISC.
in the haynes manual it shows u how to test the ISC with a ohmameter. i did that and its testing out fine.
the ISC is a dealer part and its 100-115 bucks. id like to know if thast what it is before i replace it or if something else would be causing it to click.
if anyone knows whats wrong here id love to know
