Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Oct 14th, 2002, 09:34 PM   #16 (permalink)
LittlebittaContact
Nissan Fanatic
LittlebittaContact's Avatar
Send a message via ICQ to LittlebittaContact Send a message via AIM to LittlebittaContact Send a message via Yahoo to LittlebittaContact
yup...ok then im lost
Scars Heal, Glory Fades
All we're left with are the memorys we made.
LittlebittaContact is offline   Reply With Quote
Old Oct 14th, 2002, 09:39 PM   #17 (permalink)
RobbieJackson
Posts: n/a
ya, the only other thing I was thinking of doing was to go to a junkyard and try to buy the hole intake and computer out of another car. I talked to an import shop in our town and they said I could get $1000 dollars into parts and still not have it fixxed. I was lost too.
Old Oct 15th, 2002, 03:41 PM   #18 (permalink)
LittlebittaContact
Nissan Fanatic
its hard to decipher a problem when you dont see broken pieces.
Old Oct 16th, 2002, 01:03 AM   #19 (permalink)
Crazy-Mart
Kick ass 1.5L / Mod
Crazy-Mart's Avatar
Send a message via ICQ to Crazy-Mart Send a message via MSN to Crazy-Mart Send a message via Yahoo to Crazy-Mart
have you tried reseting the computer ????..... it could just do it !!... lot of erratic problem could be fix like that when you changed parts and stuff.... just unplug the batterie for 5 minutes... and plug it back.. start the car again let it warm up on idle then shut it down and after that start it again ... should be a bit better !!
Crazy !
Sentra Sport Coupe 87 Turbo
14.850@97.454mph
H&R Spring, 15psi, TMIC, 370cc, Nismo mount and pulley, Almasi tuned ecu...
Crazy-Mart is offline   Reply With Quote
Old Jan 7th, 2005, 03:38 PM   #20 (permalink)
Alchemy
sorry for bringing up an old post , but i have the exact same problem with my 87 e16i and ive brought it to nissan dealership and they couldnt fix it. they didnt know what it was.can anyone help?
Alchemy is offline   Reply With Quote
Old Jan 7th, 2005, 04:03 PM   #21 (permalink)
blownb310
Sentra Specialist
blownb310's Avatar
What parts has the dealer tried so far? What was the fuel pressure? It's more than likely either the air mass meter or the throttle sensor, in that order.
'93 SE-R
'89 B12 4WD GA16DET
'86 B11 Euro-Rallycross car
'81 Datsun 210
'77 Datsun B210
blownb310 is offline   Reply With Quote
Old Jan 7th, 2005, 06:56 PM   #22 (permalink)
Alchemy
dealership did all the standard checks , such as plugs , wires , distributor cap ,etc.. he had a look at all the vacuum lines. ive replaced the tps already and adjusted it. is the air mass meter the same as an air flow meter? if my afm was bad wouldnt the car not rev above about 2700 rpm? only does it when the car is warm and under load, ive heard it could be the ignition coil, is that possible?
and the guy who originally posted this who had same problems i have , replaced his afm and it didnt fix anything.
Old Jan 7th, 2005, 09:08 PM   #23 (permalink)
blownb310
Sentra Specialist
blownb310's Avatar
Is the air mass meter the same as an air flow meter?
Yes
Yes it could be the ignition coil, or about 20 other things. You won't find it until you eliminate the most common offenders for a problem like this. The ecu does not rely on the signal from the air mass meter during cold starts and through the warm up period. The ecu has fixed injection pulse maps for those operating conditions. It isn't until the car warms up and the ecu goes into "closed loop" that the air mass meter's inputs are important. Hence, the reason it runs good cold. Same goes for the oxygen sensor. One other detail, Nissans 5- mode checker box cannot detect a bad air mass meter. That's another reason the dealer couldn't find anything wrong. I'll bet they got a code 55 out of it, [normal].
I can tell you right now, that I have fixed so many of these cars with this same problem, that I would start with the air mass meter first and work from there. I do things differently than most, because I have every spare part for that car imaginable. I don't decide what part to change first based on how expensive it is, I decide by starting with what is the most commonly failure prone. I do all my basic system checks first [like you did] and when it gets to the point your at, I get out an air mass meter and usually, it's fixed.
Good Luck
'93 SE-R
'89 B12 4WD GA16DET
'81 Datsun 210
'77 Datsun B210
Old Jan 10th, 2005, 06:13 PM   #24 (permalink)
Alchemy
hopefully i can find one at a junkyard , nissan dealership wants 270 bucks(canadian) for the part :s
Old Jan 10th, 2005, 06:19 PM   #25 (permalink)
Alchemy
i had my air cleaner off the other day with the car running , and when the car warmed up, it was burnning oil through the metal pipe that runs from exhaust to air cleaner and tons of smoke was coming out of the end of the pipe with the air cleaner off.yet i get no sut or anything out the back of the car. what can cause this , and how can i fix it?
Old Jan 20th, 2005, 08:25 PM   #26 (permalink)
old_sentra
well my sentra have the same trouble about 3700 rpm until it's warm
a nissan tech told me it can be the coolant temperature sensor and the air flow..
well i dont try it again because of the temperature outside about -45..
but if someone can say me if it work..
old_sentra is offline   Reply With Quote
Clock, antenna, engine and trunk lid problems. Engloid U13 1993-1997 Altima 9 Nov 19th, 2003 03:03 AM
92 g20 engine problems j2qt4u28 General Discussion 0 Jul 24th, 2003 03:52 PM
my 200sx down???????? engine problems down4myne GA16DE 1.6L Engine 3 Mar 30th, 2003 08:45 PM
Few engine problems greensentra B14 95-99 chassis 3 Feb 24th, 2003 07:45 PM
240SX USA version... Engine problems? dugrant153 S13 240SX 1989-1994 15 Nov 5th, 2002 10:26 AM
