Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Mar 29th, 2004, 12:03 AM   #1 (permalink)
87SXS12
87SXS12's Avatar
Question CA20E running problem help!!!
Ok here it goes I just bought a 1987 200SX with the 2.0L SOHC CA20E motor and an automatic tranny (soon to be changed to 5-speed) I have a slight problem I cant figure out maybe it is a common problem. I am new at Nissan I belong to Mitsubishi at heart. Well here it goes
The problem:
When I floor the engine or put it under a load it slightly hesitates between 2000rpm and 3500 rpm then as soon as it gets to 4000rpm and up it totally starts to lack power and stumble badly struggling it reaches about a top speed of about 75mph stumbling the whole way. Reves fine in park and neutral when I pull the plugs all look perfect accept cyclender 2 they are always fowled with black soot. Also the car idles like a chevy 350cid with a 3/4 racing cam. I don't get it its driving me MAD !! when driving normal not under a load it runs perfect HELP!!
What I have replaced:
Fuel filter,plugs,cap,wires,rotor,Catalitic converter,O2 Sensor,Airfilter,cleaned Throttle body, fuel system cleaner in Gas (good stuff not cheap),One broken vacuum line (looked for hours for more no more where cracked or broken)
Please i hope someone can help me i want this car to run great and i want to put performance mods on it but i need it to run good first and i have a lot of mechanical experience but this is stumping me thanx guys
87SXS12 is offline   Reply With Quote
Old Mar 29th, 2004, 05:04 PM   #2 (permalink)
Myetball
Nissan No More
Myetball's Avatar
Send a message via MSN to Myetball
I'm thinking ignition module...little black doohicky in the distributor. Very expensive to buy new but worth a trip to the junkyard to pocket a few...if you can find them. Stanza's and Axxis vans also used the CA20E.
Nissan Forum Members that have ripped me off/owe me money:
Nicholas Smaldone hpi911t@yahoo.com Steven M. Castano wcdbsteve@yahoo.com & stan410@aol.com
187-A Extended Bowery Street__________22 Potomac Lane
Frostburg, MD 21532__________________Sayville, NY 11782 (631) 563-1292
Myetball is offline   Reply With Quote
Shift boot problem SteveSXSE B14 95-99 chassis 6 Jul 24th, 2006 08:20 PM
daytime running light problem stephenho56 Canada & International 12 Aug 30th, 2004 10:32 PM
Headlight problem Marcus Truck & SUV 6 May 28th, 2004 06:36 PM
Tiny (?) electrical problem - 92 SE-R RED92SE-R B13 91-94 chassis 10 May 17th, 2004 12:38 PM
problem when starting 97sentragxe B14 95-99 chassis 4 Apr 20th, 2003 01:20 PM
