Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Mar 25th, 2004, 09:59 PM   #1 (permalink)
ReydraX
Exclamation E16i Problem Need Help Fast
O.k. I did on my Sentra 88' a engine swap, because I my Transmision was Burning and I waited to long until it went out and in the process of burning completetly it messed up my engine. (I went to a mechanic to ask questions and want I can do about it!) But I ordered a pretty new engine don't know if it really works, but hope it does. I really need help on how to find out what is worng with my car now I did the swap and all wires were plug up, but I got everything ready and turn the key and I get no car turning on. I only hear a nose from the engine it self that comes on for 2 seconds and stops. I think it is the fuel pump, but I got no starter working. I got the starter tested and it good and working, but I don't know were else too look? I need mayor help can some one hel me?
ReydraX is offline   Reply With Quote
Old Mar 25th, 2004, 10:25 PM   #2 (permalink)
Gsolo
Post Freak
Gsolo's Avatar
Send a message via MSN to Gsolo Send a message via Yahoo to Gsolo
wow, i hate these kind of things cause its hard to help someone when you can't see the damn thing. All I can think of is double check all electrical connections, fuel pump, ECU, Fuel lines, coil......cam timing.....i dunno, anyone else wanna take a stab at this??????
Student at UTI Avondale
2nd place SkillsUSA/VICA WA State Automotive Maintenence '04
had an 87 pulsar...still planning CA20DET
1970 Chevy BelAir 350V8 300hp...soon to get M21
Gsolo is offline   Reply With Quote
Old Mar 25th, 2004, 10:54 PM   #3 (permalink)
ReydraX
Exclamation Roger
Thanx for the Input I'll keep looking for those things I hope to find the solution soon.
Old Mar 26th, 2004, 08:21 AM   #4 (permalink)
minute rice sentra
coming soon... CA18DET!!!
minute rice sentra's Avatar
Is the starter even kicking on?
My sentra! My 200SX! My Brother's 300Z!
Originally Posted by red_devil
may the boost be with you.
minute rice sentra is offline   Reply With Quote
Old Mar 26th, 2004, 04:47 PM   #5 (permalink)
ReydraX
Engine Help
No, the starter is not even kikcing on, but I got it tested and it was good. Is there supose to be a Red wire from the battery and a Black wire from the battery and a small ground looking wire hooked up to the starter?
Old Mar 26th, 2004, 05:02 PM   #6 (permalink)
recycled_toddler
Moved on...Ciao!
recycled_toddler's Avatar
Lightbulb
Red cable from battery to starter 'big lead'; It grounds through the transaxle case, which has a cable going from it to the battery black cable. The little terminal on the starter (Solenoid), when given 12 volts, cranks the engine.
Later, taters; Off to a better place. Catch me there!
recycled_toddler is offline   Reply With Quote
Old Mar 28th, 2004, 12:18 PM   #7 (permalink)
ReydraX
Starter Plugins
So does the starter have bolted on it a red only wire, what about a wierd black small wire coming from the chassi on the transmission side on the back were the brake fluid is at. There is a small flat looking plug for a wire but I can't find one or don't know what wierd goes there.
Old Mar 28th, 2004, 02:26 PM   #8 (permalink)
Gsolo
Post Freak
Gsolo's Avatar
there is a wire somewhere for it (if you're talking about what i thin kyou're takling about) I tested mine without that thing plugged on and it didn't make a difference.
edit: although i never tried starting it without that ! could be a ground for the starter you never know, find somethign that plugs onto it or just use a good wire to ground it see what it does........someone else confirm though that i know what i'm talking about so that i dont sound like a :dumbass: a mess up this poor guys car
Old Mar 28th, 2004, 06:03 PM   #9 (permalink)
recycled_toddler
Moved on...Ciao!
Unhappy
I don't think you can do the poor car any worse. It's hell fixing a car online; It's like trying to solve a Rubik's cube blindfolded.
Old Mar 28th, 2004, 06:09 PM   #10 (permalink)
Gsolo
Post Freak
Gsolo's Avatar
i cant' even talk i'm laughing so damn hard....whats even funnier is I can't solve a rubiks cube with my eyes open
Old Mar 28th, 2004, 06:32 PM   #11 (permalink)
minute rice sentra
your starter should resemble something like the one in the pic. There will be one small wire coming off the starter, and another larger wire going to the positive battery terminal. It may look different but the readings will be the same.
Old Mar 28th, 2004, 07:15 PM   #12 (permalink)
bullit
I had the same problem this weekend
I replacd the motor in mine this weekend and had the same problem. With mine it turned out to be a mixed up plug between ox sensor and distributor. I think these plugs are the same and when we laid out our harness everything fit like a charm but.... we still messed up. I changed those two plugs and it fired up right away. hope this helps.
Tyler
bullit is offline   Reply With Quote
Old Mar 28th, 2004, 09:34 PM   #13 (permalink)
Gsolo
Post Freak
Gsolo's Avatar
i think minute rice's starter looks funky compared to mine......i'll look at mine in the light tomorrow.
Old Mar 28th, 2004, 09:41 PM   #14 (permalink)
minute rice sentra
it was a new starter before I got the car a couple years ago, the one on my E16s (auto) looks like that too but the one off the pulsar (CA18 auto) has a wire coming off it with a connector on the end. Mine e16 has a manual tranny too.
Old Mar 28th, 2004, 09:44 PM   #15 (permalink)
Gsolo
Post Freak
Gsolo's Avatar
I'm just wondering if the E16i from the pulsar has different wiring, cause its a different starter altogether too. Well, not completely different, but they aren't interchangeable.
E16i ---> GA16i PSAudio E/CA-Series & GA16i Engines 5 Jun 26th, 2003 02:19 AM
Hi all, I'm new here. Got a problem with my B14, pls help. Mayonaise B14 95-99 chassis 8 May 12th, 2003 06:03 AM
Starting problem!?? 93altima U13 1993-1997 Altima 2 May 7th, 2003 07:51 PM
So, I got wider tires... now I have problem. Dynamitega Cosmetic Mods 25 Apr 14th, 2003 12:50 AM
Warm weather idling problem grray
