Valve clearance on NISSAN E15 (S) Engine - Nissan Forum
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
post #1 of 19 Old Mar 3rd, 2004, 07:34 AM Thread Starter
Does anybody know what is the valve clearance for inlet and outlet for this type of engine? The car is Nissan SUNNY (SENTRA) made in 1985?
Thank You,
Relmas is offline
post #2 of 19 Old Mar 4th, 2004, 12:42 AM
Moved on...Ciao!
recycled_toddler's Avatar
Lightbulb
All E-series engines require .011 inch (.28 mm) clearances for intake and exhaust valves. Engine must be full warm to adjust...as well as turned off (Giggles...not to imply you don't realize that; Just thought a funny was in order )
Later, taters; Off to a better place. Catch me there!
recycled_toddler is offline
post #3 of 19 Old Mar 4th, 2004, 03:05 AM Thread Starter
Thank You for information, but for cold operation there is no value.? Will be very dificult to do this with hot engine (burn fingers, etc).
I know it is better with hot, but maybe adjust them cold and only check hot...
Relmas is offline
post #4 of 19 Old Mar 4th, 2004, 02:16 PM
Post Freak
Gsolo's Avatar
Send a message via MSN to Gsolo Send a message via Yahoo to Gsolo
if you really realy really wanted to you could adjust while engine was running...but i dont think i would
Student at UTI Avondale
2nd place SkillsUSA/VICA WA State Automotive Maintenence '04
1970 Chevy BelAir 350V8 300hp...soon to get M21
Gsolo is offline
post #5 of 19 Old Mar 4th, 2004, 04:19 PM
just rattle can it
BeEleven's Avatar
Send a message via AIM to BeEleven
are you guys talking about tappet-valve clearance or valve-piston clearance
Why did I pick such a slow car?
BeEleven is offline
post #6 of 19 Old Mar 4th, 2004, 05:13 PM
Datsun Guy
B11sleeper's Avatar
Send a message via AIM to B11sleeper
on my e16 we adjusted clearances while it was running because my valve train has a bit of lash and doing it while the engine was stopped didn't get it right.
it's a bit messy with the spraying oil, but not too bad.
1981 datsun 210.
B11sleeper is offline
post #7 of 19 Old Mar 4th, 2004, 08:30 PM
Post Freak
Gsolo's Avatar
And i've heard .010 inch. Not that it makes much difference...but yeah
Gsolo is offline
post #8 of 19 Old Mar 4th, 2004, 09:01 PM
Post Freak
minute rice sentra's Avatar
I do 10 when it's warm just so it'll run a little quieter.
Originally Posted by red_devil
may the boost be with you.
minute rice sentra is offline
post #9 of 19 Old Mar 4th, 2004, 09:49 PM
Post Freak
Gsolo's Avatar
i need to do it here soon...anything special about this engine i should know about when setting valve?
Gsolo is offline
post #10 of 19 Old Mar 4th, 2004, 10:13 PM
Post Freak
Not really, Just make sure The cylinder you're working on is right at TDC of compression stoke and try to do it while the engine is warm for best results. You might want to grab a VC gasket set/W grommets if your valve cover leaks at all. I think that's all you really have to worry about.
post #11 of 19 Old Mar 5th, 2004, 08:12 AM Thread Starter
Maybe 0.10 is for cold engine and 0.11 is for hot.
Also another question:
The numbering of cylinders start from left to right? I mean number 4 near the water pump?
Thanks.
Relmas is offline
post #12 of 19 Old Mar 5th, 2004, 09:57 AM
Post Freak
The cylinder closest to the front of the engine is #1. Setting the valves at .010" isn't stated in any manuals or anything, they all say to set it to .011. Someone on the forums said that they set the valves to .010 so I tried it and it runs it little quieter now. There's probably more valve float at high rpms but there's no power up there anyways.
post #13 of 19 Old Mar 5th, 2004, 11:51 AM
just rattle can it
BeEleven's Avatar
Actually I've heard that you always set the exhaust valves with a little more clearance so I set mine to 11 and the intake valves to 10...both cold settings.
BeEleven is offline
post #14 of 19 Old Mar 5th, 2004, 01:17 PM
Moved on...Ciao!
Exclamation
Thanks.
The numbering starts at the fan-belt end of the engine, working back. And as far as valve clearances, I'd run .011 regardless of intake or exhaust. That provides time for the valves to transfer heat to the seats and out through the head so they don't burn up, especially the exhaust valves. Tight exhaust valves are the #1 reason they burn up.
post #15 of 19 Old Mar 5th, 2004, 08:16 PM
Post Freak
Gsolo's Avatar
yep. And i looked it up today,
.011 warm and .009 cold.
Its recommended warm though, the only time you do cold is from an overhaul/rebuild.
And I bolded that for anyone who's gonna look it up later
Gsolo is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
EVAP canister vent control valve closed large168 SR-Series Engines (DE/VE) 45 Mar 24th, 2013 01:08 PM
Nissan N16.... engine details! eranga General Discussion 8 Feb 25th, 2009 10:57 AM
Do You Have a Nissan More than 10 years old ? You are challenging Nissan...read Pablo14 General Discussion 34 Oct 18th, 2007 01:53 AM
SEMA show Spec V's and other Nissan GOODIES cjsmith11878 General Discussion 13 Jan 26th, 2005 10:51 AM
A manual from Nissan explaining improvements over the GA16DE engine Pablo14 GA16DE 1.6L Engine 4 Nov 3rd, 2004 06:48 PM
You may post new threads
You may post replies
BB code is On
