Originally posted by fastpakr How much did they charge for the diesel hubs?
$50. but they don't have any more.
nor do they have any more turbo heads. ("regular" heads they still have, i believe...)
they still have blocks, tho... and with a little "persuasion," i may be willing to go pick out a good one for ya.
's like shootin' 'tards in a bucket.
Originally posted by Dean GXE How did you know it was an e15 just by looking at it?
The block is indistinct (E16 or E15) but the E15 head has smaller dish-shaped combustion chambers than the E16. I swapped an E15 head onto my E16 block to take advantage of that fact and gain compression.
Originally posted by BeEleven The block is indistinct (E16 or E15) but the E15 head has smaller dish-shaped combustion chambers than the E16. I swapped an E15 head onto my E16 block to take advantage of that fact and gain compression.
only some E15 engines had the groovy heads... MPGs, Turbos... in this case they're toibo heeds, but the block (technically) is an E16.
Uh...if by groovy he meant "better than E16" then you either have a turbo or MPFI...thats all it means...its not really all that special if theres an E15 head on an E15 block, but if you have a "groovy" head on your E16, then your getting several performance enhancing features (larger intake bore, thicker casting, smaller comb. chamber) different than stock.
__________________ Why did I pick such a slow car?
Originally posted by Lazarus_023 head trick? you mean the turbo/FI head? ab-so-smurf-ly! that's why i got them... they'll raise compression a bit, and are a thicker casting.
...what ecu and wiring setup are you gonna use then
or are you keeping it tbi?
__________________ Student at UTI Avondale 2nd place SkillsUSA/VICA WA State Automotive Maintenence '04 had an 87 pulsar...still planning CA20DET
1970 Chevy BelAir 350V8 300hp...soon to get M21
