Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Jul 18th, 2003, 04:08 PM   #1 (permalink)
phaedrus432
Exclamation help! Car going to sh*t!
Damnit! My muffler fell off the other day and my negative battery terminal won't tighten... Both these probs are getting fixed after I'm done posting this... The main prob is: When cold starting, my engine races so bad it smokes, then when I give it some gas the RPM's drop and it stumbles really bad and then dies... Even when the engine is warmed up it still stumbles really bad through the lower RPM's, and has absolutely no power in the higher RPM's.... I fear the worst......... help....
"If there were no rewards to reap, no loving embrace to see me though this tedious path I've chosen here, I certainly would've walked away by now.... And I still may." - Maynard James Keenan
phaedrus432 is offline   Reply With Quote
Old Jul 18th, 2003, 05:54 PM   #2 (permalink)
fastpakr
Nissan Fanatic
fastpakr's Avatar
Do you have a tach? How fast is it turning on a cold start? That may be perfectly normal (although the smoke is not). Have you checked your timing and carefully inspected for vacuum leaks?
84 Ford Bronco II 2.8
86 Ford Bronco II 2.9
86 Nissan Pulsar w/ Weber and CA distributor (gone, but not forgotten)
fastpakr is offline   Reply With Quote
Old Jul 18th, 2003, 07:16 PM   #3 (permalink)
Myetball
Nissan No More
Myetball's Avatar
Send a message via MSN to Myetball
Also what color is the smoke...does it smell like oil or coolant? What I'm gettin' at is you may have a bad head gasket.
Nissan Forum Members that have ripped me off/owe me money:
Nicholas Smaldone hpi911t@yahoo.com Steven M. Castano wcdbsteve@yahoo.com & stan410@aol.com
187-A Extended Bowery Street__________22 Potomac Lane
Frostburg, MD 21532__________________Sayville, NY 11782 (631) 563-1292
Myetball is offline   Reply With Quote
Old Jul 19th, 2003, 05:05 PM   #4 (permalink)
phaedrus432
The smoke is typical piece-o-shit-car bluish white... As for a tach... anyone with even the slightest knowledge about cars could take a listen to mine and tell that the RPM's are WAY too high... I replaced all my vaccuum lines and fittings a month or so ago so I doubt that's the problem (thought that's on my list of shit to check).... Perhaps could the sudden loss of back pressure in the exhaust system have caused this somehow? *sigh* I miss my old VW's... hehe, you can fix any problem with bailing wire and duct tape.....
Old Jul 19th, 2003, 05:45 PM   #5 (permalink)
minute rice sentra
coming soon... CA18DET!!!
minute rice sentra's Avatar
the backpressure decrease wouldn't cause this. on cold starts my engine idles up to about 1200 rpm til the engine is warm then it stays @ 800. My muffler rusted off ~2 weeks ago and i have a hollow cat and a tach and my rpms didn't change at all. do you have the e16s cuz if you do then chances are it's something wrong with the carb if you don't touch the petal and rpm's just jump real high.
My sentra! My 200SX! My Brother's 300Z!
Originally Posted by red_devil
may the boost be with you.
minute rice sentra is offline   Reply With Quote
Old Jul 19th, 2003, 06:07 PM   #6 (permalink)
fastpakr
Nissan Fanatic
fastpakr's Avatar
Look for a vacuum leak. You're dealing with two separate problems here - the smoke shouldn't be related to the idle speed at all. You really do need to get a tach so you know exactly how fast it's going though. Once you know that you have a little idea of how big a leak you're looking for. Check all vacuum hoses going anywhere in the intake tract below the throttle plate of the carb. Could the throttle also be sticking? Try disconnecting the throttle cable from the carb so you can work directly with the carb to ensure that it's fully closed.
Old Jul 19th, 2003, 07:01 PM   #7 (permalink)
Myetball
Nissan No More
Myetball's Avatar
Assuming you have a carb and not tbi, the high cold idle is controlled by the idle speed control valve. It's the big black thing on the front/drivers side of the carb. Here's a pic of the vacuum system with the ISCV lines colored.
Make sure all these lines are in good order.
The stumbling and loss of power is either elctrical or fuel related. Check out your ignition system, cap/rotor, plugs, timing, etc. If it's fuel it may be your carb is on it's last leg.
