GA16de transmission on a ga16i engine? - Nissan Forum
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
post #1 of 4 Old Feb 6th, 2013, 02:17 PM Thread Starter
hey guys im wondering if it is possible to swap a 91 sentra ga16de transmission onto a ga16i? i have a parts car b13 and i want to convert my 89 b12 to manual and none of our junkyards have a manual. so any info would be great.
i know i need the fallowing
shift linkage
b12 manual ecu or could i just run the auto ecu?
the complete shifter aseembly in the center column.
the clutch pedal assembly
the clutch cable.
the transmission motor mount
and i think that is it.
as far as wiring goes what would i have to change on the wire harness for the manual.
Wesleyb12 is offline
post #2 of 4 Old Mar 25th, 2013, 05:53 PM
800+ posts
BeyondBiscuits2's Avatar
Send a message via MSN to BeyondBiscuits2 Send a message via Yahoo to BeyondBiscuits2
I ran a GA16i transmission on my B12 GA16DET, and that is because I noticed the many differences between the two transmissions. First, the DE transmission uses a different spline on its CV axles, so you'd have to replace the hubs as well as the halfshafts. Also, the transmission mounts are different, so be prepared to change those. Also, depending on what year DE transmission it is, it may be electronic speedo. But, they are MUCH easier to find than a 16i, so good luck! I am not sure about shift linkage and such.
The Sentra Channel:
Subscribe Today!
1990 Nissan Sentra B12 GA16DET
1985 Nissan Fairlady Z 300ZX Z31 2+2
2002 Acura RSX Type S
BeyondBiscuits2 is offline
post #3 of 4 Old Mar 30th, 2013, 09:09 AM
800+ posts
Also, as I just remembered, the B13 GA16DE transmissions had a horrible problem with 5th gear popout. I don't recall a GA16i transmission ever having the same issue, though I could be wrong.
The Sentra Channel:
Subscribe Today!
post #4 of 4 Old Jun 2nd, 2013, 11:21 PM
Post Freak
ahardb0dy's Avatar
OEM Surplus: Sentra
still lists brand new surplus 5 speeds as being available for $400, I bought one from them for my 90, was delivered brand new in the nissan crate think I got it for $450 delivered !! Check them out if you are still looking for a tranny before they sell out of them.
I come on these forums to help if I can, if I say something wrong and someone corrects me I also learn something.
Current Nissan:
93 Hardbody king cab, 2wd, KA24E with the 5 speed
Previously owned:
90 Nissan Sentra
94 Nissan Pathfinder
05 Nissan Titan 2wd
94 Infiniti Q45t
87 Nissan Hardbody SE-V6 4WD
80 Datsun 310GX (first Datsun/Nissan)
ahardb0dy is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
Gear in this thread
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
