» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old May 12th, 2007, 06:21 PM   #1 (permalink)
Send a message via AIM to X-Ray Send a message via MSN to X-Ray Send a message via Yahoo to X-Ray
Major Fuel Problem
I have recently replaced the fuel pump on my e16s engine and for some reason i am not getting fuel to the carburetor
i checked the lines to the fuel tank and they were clean
i took the tank off to check if the fuel pickup filter sock thingie was clean and it was very clean
tank was shiny and normal on the inside and the pickup filter sock thingie is soaked in gas when i pull the sending unit out
what could be my problem
i need this fixed soon
speed is much appreciated
thanks
X-Ray is offline   Reply With Quote
Old May 17th, 2007, 07:17 AM   #2 (permalink)
Did you fill the tank with fuel ?
the pump might have air in it and won't give fuel to engine unless it's filled with fuel.
So first - try to fill the tank to the top.
I'm not sure how it works on a carburetor engine, but on mine E16i (injection) I would then turn key to ON, wait to hear the pump running until it turns itself off. Then turn key to OFF for about 30s. Then again ON - hear pump - OFF... some 10 to 20 times.
Ondrej P. from Slovakia
Nissan newbie, D.I.Y. kind'a'guy
ondrejp_sk is offline   Reply With Quote
Old May 17th, 2007, 07:21 AM   #3 (permalink)
i finally figured out the problem
took my tank 100% out instead of just leaning it down to look inside
i looked in the hole and there was just bare metal
not enough gas in there to pick up
which is odd because the gas light never came on
hmmmm
Old May 17th, 2007, 04:29 PM   #4 (permalink)
Nissan Addict
greenbean699's Avatar
hmmmm
The gas light never came on because its not a light. Just a indacatior.
Unless your nissan is totally different than all i have seen.
'08 Sentra 2.0 S--chrome billet grille
'92 xe---HS CAI, ES Motor Mounts, SE-R swaybars w/poly bushings
'89 w/ga16de swap---DOHC pulsar SE swaybars, rear SE-R brakes coming soon
'87 rare sentra h/b w/ca18de--DOHC sway bars
'89 sport coupe---future swap.....I'm hungry for Boost
Originally Posted by Campground Man View Post
I've always said - beware of the guy with primer on his car!
greenbean699 is offline   Reply With Quote
1995 altima gxe problem acg1304 U13 1993-1997 Altima 4 Jun 10th, 2005 01:08 PM
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
Sentra vibrations and other problem premk71 B15 2000-2006 8 May 13th, 2005 07:09 AM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 08:18 AM
Hi all, I'm new here. Got a problem with my B14, pls help. Mayonaise B14 95-99 chassis 8 May 12th, 2003 06:03 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
