Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Sep 30th, 2006, 08:21 PM   #1 (permalink)
winstonsmith
winstonsmith's Avatar
engine mount help - E16s
My engine (e16s) jumps when I put it in reverse but not when I put it in drive. Clearly I have a bad engine mount but I can't see the engine when I'm putting it in gear and I don't have anyone to look at it while I do it so which mount is bad? The front or the back? I know it's not the sides.
winstonsmith is offline   Reply With Quote
Old Oct 2nd, 2006, 11:39 AM   #2 (permalink)
bob89sentra
GA16I Guy
bob89sentra's Avatar
If the engine "Jumps" when you put it in reverse, it is probbaly both front and rear "Dogbone" mounts. You should be able to see if the rubber in the ends of the mount fits tightly, or not. If it was loose, a new mount would be needed
89 Sentra owner 9 years 205,000 miles and counting!
bob89sentra is offline   Reply With Quote
ka pull out of an 89 240sx 240droptop S13 240SX 1989-1994 3 Apr 21st, 2005 10:16 PM
E16s engine overhaul questions Jericho E/CA-Series & GA16i Engines 2 Feb 24th, 2004 05:33 PM
do a GA16's engine mount similar to e16i's? yafayu GA16DE 1.6L Engine 0 Jul 5th, 2003 01:29 PM
Valve lash on a E16S engine BluEyes B11/B12/KN13 82-90 chassis 4 Jun 27th, 2003 10:06 PM
Valve lash adjustment on E16S engine BluEyes New Member Forum 0 Jun 22nd, 2003 04:57 PM
