Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Oct 2nd, 2005, 03:23 PM   #1 (permalink)
NissaN_Nos
NissaN_Nos's Avatar
Question Engine problem I can't solve...
Well here are the symptoms:
-idles rough
-Has a miss when it idles
-stalls out when gas I press on the gas and release
-If it is left idling it won't stall
I've done a basic tune-up
-pcv valve
-air filter
-spark plugs
-ignition wires
-rotor
-distributor cap
Any suggestion on what it may be...because I'm lost...
NissaN_Nos is offline   Reply With Quote
Old Oct 2nd, 2005, 03:41 PM   #2 (permalink)
Nissan300ZXZ31Turbo
Nissan Fanatic
what type of engine? E-series, GA16i, or CA-series? Sounds like vaccuum or mass-airflow problems to me.
Nissan300ZXZ31Turbo is offline   Reply With Quote
Old Aug 12th, 2007, 11:19 AM   #3 (permalink)
Kikbaq
I think I am experiencing the same problems w/ my 85 pulsar. all my vac lines have been checked and are 100% functional. I still experience this problem with me car. Mine is the E16 w/ 5 speed Tranny.
Good luck to any and everybody who can solve this.
Chris Aitken
Kikbaq is offline   Reply With Quote
Old Aug 17th, 2007, 05:16 PM   #4 (permalink)
joeli16
Nissan Fanatic
I am also experiencing this kind of problem with a 89 pulsar (GA16i).I am totally lost of what is happening to the car.See the thread below
http://www.nissanforums.com/e-ca-ser...l-problem.html
I am hoping someone will find the problem.My mechanic and everybody who tried to work it out were completely lost.
joeli16 is offline   Reply With Quote
Old Aug 18th, 2007, 06:43 PM   #5 (permalink)
greenbean699
Nissan Addict
greenbean699's Avatar
might want to try replacing the O2 sensor
'92 xe---family car
'89 w/ga16de---work car
'87 rare sentra h/b w/ca18de---honda killer
'89 sport coupe---future swap.....
Originally Posted by Campground Man View Post
I've always said - beware of the guy with primer on his car!
greenbean699 is offline   Reply With Quote
Old Jan 9th, 2008, 10:31 AM   #6 (permalink)
PulseMan
Replace all the vaccum lines for the E-series. I ran into this problem especially in cold
weather before I replaced the damn thing with a Weber.
And make sure the choke is spot on after a extreme cleaning. Use some air/fuel ratio tester.
hese carbs can be really damn anal when the choke gets aged.
Worst case is that you have a intake manifold leak that causes the problems when you do the same things.
PulseMan is offline   Reply With Quote
Old Jan 9th, 2008, 10:54 AM   #7 (permalink)
bob89sentra
GA16I Guy
bob89sentra's Avatar
Anyone with a GA16I check the Fast Idle Control Device solenoid (FICD), the Auxiliary Air Control solenoid (AAC), and the Idle Up solenoids. I have a write-up here... The GA16I Sensors How to Thread - AllNissans.com - NPM Forums
89 Sentra owner 9 years 205,000 miles and counting!
bob89sentra is offline   Reply With Quote
2004 & 2005 Armada brake problem Shannonop Titan & Armada 11 Aug 5th, 2007 02:33 PM
Murano engine rev problem NauTiCa General Discussion 0 Aug 27th, 2005 12:38 PM
engine problem nismorac3r GA16DE 1.6L Engine 2 May 19th, 2005 12:41 PM
Engine problem Pls Help Austin Augie QG18 1.8L Engine 1 Jan 7th, 2005 09:53 AM
engine problem jwanyoike New Member Forum 1 Jan 3rd, 2005 01:14 PM
