Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Sep 4th, 2005, 06:56 PM   #1 (permalink)
Nissan300ZXZ31Turbo
Nissan Fanatic
CA20 aftermarket parts
Does anybody know of any good websites other than Nismoparts.com that cover aftermarket parts for a Datsun 200SX S12 CA20E engine? Also, does anybody know if I can use parts from a CA18 or CA16 on the engine, since they are in the same engine series? I would love to be able to put a CA18 DOHC cylinder head on the CA20 engine block, if that is possible.
Nissan300ZXZ31Turbo is offline   Reply With Quote
Old Sep 5th, 2005, 11:11 AM   #2 (permalink)
BakaSama
SR20DE powered.
BakaSama's Avatar
What find of aftermarket parts are you looking for?
As for the DOHC conversion, yes the head bolts up with out problems, but there still the issue of the timing belt as the CA20's deck height is about 18MM (I think) higher than the 16/18DE, so a custom timing belt would be needed.
BakaSama is offline   Reply With Quote
Old Sep 7th, 2005, 08:55 AM   #3 (permalink)
Nissan300ZXZ31Turbo
Nissan Fanatic
Custom timing belt would not be a problem. I was looking specifically for better fuel injectors, valves, pistons, and crankshaft. I have a CA18DE laying in the garage I could scavenge for parts, but that engine has not run in about six years, I think.
Old Sep 7th, 2005, 11:23 AM   #4 (permalink)
BakaSama
SR20DE powered.
BakaSama's Avatar
Valves, pistons, and connecting rods would all have to be custom made. The stock crank shaft is about as good as it's going to get, it's already forged.
You can use pretty much any injector you want, but you might need a custom fuel rail depending on which ones you use.
Old Sep 9th, 2005, 12:33 AM   #5 (permalink)
Gsolo
Post Freak
Gsolo's Avatar
Send a message via MSN to Gsolo Send a message via Yahoo to Gsolo
just use the fuel injectors and rail from the ca18det. do a search on the dohc swap, and check out exaclub.com
as for anything just for the ca20e...theres not going to be much out there to find. Most of it is going to be good ole ingenuity and research
Student at UTI Avondale
2nd place SkillsUSA/VICA WA State Automotive Maintenence '04
had an 87 pulsar...still planning CA20DET
1970 Chevy BelAir 350V8 300hp...soon to get M21
Gsolo is offline   Reply With Quote
Found Aftermarket Parts!! Gsolo B11/B12/KN13 82-90 chassis 39 Apr 8th, 2004 10:45 PM
What are good sites for Aftermarket parts for Nissan (240sx)?? I'm new japrex New Member Forum 4 Jan 27th, 2004 05:50 PM
What aftermarket parts void warranty? prius QR25 2.5L Engine 4 Jan 5th, 2004 10:37 AM
Aftermarket Parts Revisited text only sethwas B14 95-99 chassis 3 Jun 30th, 2003 12:10 PM
Aftermarket parts in Orlando Ninety-Nine SE-L South/Southeast 0 Nov 13th, 2002 07:06 PM
