Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > E/CA-Series & GA16i Engines
E/CA-Series & GA16i Engines Engine Discussion: 1982-1990 Sentra/Pulsar
Old Sep 1st, 2005, 12:21 AM   #1 (permalink)
Sentrawagon
Cooling problem???
ok guys I don't know what the problem is but my ENG bay and ENG get really hot but my temp guage dosn't go highter then half way and then fan comes on, I know that this good but the ENG gets so hot that I can't even get my hand close to it and I have rough hands. I have a haynes manual and I think it might be my water pump. #1. with the car running I squeezed the bottom rad hose and theres no pressure well for what I can feel. #2. the bottom rad hose stays hot all the time. #3. with the car off I squeezed the same rad hose and I can hear the breather on the thermostat click. if anyone can help me out it would be appreciated. Thanx
P.S. I have changed my rad out because when I bought my car there was a BIG hole in the rad. could this be for not refilling the rad right??
Sentrawagon is offline   Reply With Quote
Old Sep 8th, 2005, 06:18 AM   #2 (permalink)
ALSET
Do the fans cut back off after a few miutes?? If the fans cycle on and off then sounds like everthing is ok.
Side note; One time we put a temp probe thru the firewall into the engine compartment of a 300zx turbo and drove it around-The temp got up too 450 deg. in there but there car wasnt overheating.
Good luck!
ALSET is offline   Reply With Quote
Old Sep 11th, 2005, 11:20 PM   #3 (permalink)
Sentrawagon
yeah I think every thing is runing good now. and thanx for the info
Old Sep 12th, 2005, 05:43 AM   #4 (permalink)
mille-16i
Nissan Junkie
mille-16i's Avatar
with the engine warm and off remove the rad cap and start the engine let it run till the fans come on may be awhile slowly add water till it is full this will burp the car of all air my E16 like to trap air I have to do this about once a month due to a slow leak. Also have the heater on so the core is purged you may add about 3/4 gallon to system. and keep the resivour full
Mille's ride Check out My B12 SportCoupe
There's no such thing as a soul. It's just something they made up to scare kids, like the boogeyman or Michael Jackson. -Bart Simpson.
mille-16i is offline   Reply With Quote
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
Unusual problem solved Zen31ZR Z31 300ZX(T) 2 Feb 19th, 2005 07:45 PM
Overheating problem.. What should I do next? alkon GA16DE 1.6L Engine 4 Jan 25th, 2005 10:05 PM
Cooling Problem asleepz Z31 300ZX(T) 9 Mar 9th, 2004 03:23 PM
Problem with tranny... J30tour General Discussion 0 Apr 19th, 2003 10:50 AM
