Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Classic Datsun
Classic Datsun The cars & trucks of Nissan's yesteryear
Old Dec 2nd, 2004, 12:56 AM   #1 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
oil problems
is there there specific reson an 1985 720 shord bed pickup would start burning oil after the head gasket was replaced, never burned befor and now goes thro over a quart a month, well it is at 300,000 almost but it just started any advice would be nice hoping to sell and need to know whats wrong
Burn 17 is offline   Reply With Quote
Old Dec 2nd, 2004, 07:08 AM   #2 (permalink)
Bror Jace
Nissan Addict
Bror Jace's Avatar
Question
With motor work that extensive, it could be a lot of things ... maybe the way the valvetrain went back together?
If they took apart the head to mill it, did the shop use all new valve seals when they put everything back together?
Document it and see if it doesn't settle down after a few thousand miles.
--- Bror Jace
Bror Jace is offline   Reply With Quote
Old Dec 2nd, 2004, 04:42 PM   #3 (permalink)
SVP5TEN
Send a message via AIM to SVP5TEN
if the head gasket was just replaced and nothing else was replaced. id retorque the head bolts. im using your bottom end in my dime and i retorqued my head bolts at 50 ft lbs. you might want to double check for the naps-z head bolts. keep us updated.
SVP5TEN is offline   Reply With Quote
Old Dec 6th, 2004, 09:30 PM   #4 (permalink)
Zen31ZR
I Live Here
Zen31ZR's Avatar
Send a message via AIM to Zen31ZR
Simplest idea is that it probably got some junk in the rings while the head was off.
1992 Yamaha FZR 1000. 145 Hp, all stock..
Zen31ZR is offline   Reply With Quote
Best Engine Oil???? MCHNHED B14 95-99 chassis 70 May 15th, 2008 05:21 PM
Oil Change Destroys Engine !!! 1996 Nissan Altima andym U13 1993-1997 Altima 12 Jun 23rd, 2005 07:05 AM
Dirty Engine Oil Vin GA16DE 1.6L Engine 0 Nov 11th, 2004 05:49 AM
Lab Tested Used Motor Oil 1.8L Bror Jace QG18 1.8L Engine 12 Jul 23rd, 2004 09:42 PM
My first engine oil leak 96R50 Truck & SUV 17 Dec 31st, 2003 06:12 AM
