Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Classic Datsun
Classic Datsun The cars & trucks of Nissan's yesteryear
Old Dec 7th, 2006, 04:40 PM   #1 (permalink)
loudrms
1990 axxess check engine light
anyone out there own 1990 axxess minivan? was looking for a way to re-set the check engine light but don't have a tech book. i've never dealth w/ this situation. i was going to buy a code reader but can't even find the plug in for it. you'd think it would be easy to find, unless they buried it somewhere under the dash. i have the KA24E motor. i think they only made this model for a couple years. any help would be greatly appreciated. thanx! lou
loudrms is offline   Reply With Quote
Old Dec 7th, 2006, 11:17 PM   #2 (permalink)
B11sleeper
Datsun Guy
B11sleeper's Avatar
Send a message via AIM to B11sleeper
quick and dirty way, unhook the battery ground overnight, that usually clears em, but it may comeback in 300 miles or so if there's a problem, or even sooner.
also it's so old, there isn't a code reader you'd have to count the blinking light to decode what it's on about.
get a haynes manual for it, not too expensive and it should have a ECM blink code chart.
1981 datsun 210. nothing interesting here...
B11sleeper is offline   Reply With Quote
Old Dec 13th, 2006, 12:41 PM   #3 (permalink)
loudrms
thanks for the input. removed the negative cable overnite. that helped for a few hours. replaced the o2 sensor. light went out for most of the day and came back intermittenly after that. light has been on the last couple of days. bought a new gas cap hoping it would be something as simple as that. disconnected the negative overnite and drove it. light is still on. before it would shut off after while, now it stays on. too bad it doesn't have a hook up for a code reader. that would simplify things. surprising since i've had older vehicles w/ the code reader connection within easy reach. nissan realy makes it hard for the DIY. what's up w/ that? anyway thank you all for the helpful info. lou
Old Dec 13th, 2006, 02:30 PM   #4 (permalink)
B11sleeper
Datsun Guy
B11sleeper's Avatar
the ECM should have a way to read the code as blinking light, on the actual ECM not the dash.
It means you have another fault. could be sometihng like the TPS or AFM, older cars mostly tell you about sensor faults not real problems in the engine, over time they kill the engine, but it's a faulty sensor or a bad connection.
Is cracked exhaust manifold causing Check Engine Light to come on? MrSparkle Truck & SUV 20 Jul 27th, 2008 05:52 PM
Charging System FAQs blackmaxima88 B13 91-94 chassis 2 May 5th, 2008 01:13 AM
'96 Altima w/97 engine Check Engine Light alexaltima U13 1993-1997 Altima 0 Nov 24th, 2005 10:02 AM
'96 Altima w/97 engine Check Engine Light alexaltima U13 1993-1997 Altima 0 Nov 24th, 2005 10:00 AM
Check Engine Soon Light? fondoo B14 95-99 chassis 3 May 22nd, 2002 09:33 AM
