Go Back   NissanForums.com :: Nissan Forum > Cosmetics and Show > Car Care
Car Care Information on maintaining your vehicle's appearance
Old Mar 6th, 2005, 09:00 PM   #1 (permalink)
Nismo1997
Got Boost?
Nismo1997's Avatar
Send a message via AIM to Nismo1997 Send a message via Yahoo to Nismo1997
How to Clean Your Engine
Warm the engine by starting it up for a few minutes and then shut it off. Cover the distributor, and you can either cover the alternator and fuse box, or use low pressure spray in those areas. Wet the engine with high-pressure spray. Spray engine and compartment with Simple Green at full strength (dirty engine) otherwise use a 50/50 mix (50% Simple Green, 50% Water). Let sit for about 5 minutes. Use a brush on heavily soiled areas. Rinse with high-pressure spray, but use low pressure around electrical components. Don't forget the underside of the hood.
After rinsing, start the engine and let run until the engine is dry. Go ahead and start wiping down the painted areas-but be careful while the engine is running. After the engine is dry, wipe down and towel dry the areas that you couldn't reach when the engine was running. Finish up with Silicone Spray on hoses and plastic parts and your ready to go.
As long as you have no oil leaks, you shouldn't have to clean your engine more than 2 times a year.
Nismo1997 is offline   Reply With Quote
Old Mar 16th, 2005, 08:35 AM   #2 (permalink)
Marvin
Hates dogs,kids,NF members, and free thinkers
Marvin's Avatar
Send a message via AIM to Marvin Send a message via Yahoo to Marvin
Those of you with exposed air filter's may want to use a plastic bag and some tape or a zip tie.
Even Ice Cube calls me an OG. Ez-E would, but well, you know....he had relations with Mike Young.
Marvin is offline   Reply With Quote
Old Mar 16th, 2005, 08:40 AM   #3 (permalink)
pete?
Banned
pete?'s Avatar
Send a message via AIM to pete?
You may want to strike that part from the write up. never use silicone, it greatly reduces the life of rubber and plastic. at the very least dont use this on your tires and engine hoses.........,however, your interior is not vital to your safty so spray away in there.
pete? is offline   Reply With Quote
Old Mar 16th, 2005, 09:02 AM   #4 (permalink)
Blank
Whoa...
Blank's Avatar
Send a message via AIM to Blank
use a vinyl dressing instead... vinylex werks great, and looks good too, anything safe for tires can be used on hoses and belts, just let it drip dry first before you start the car as sometimes the propellent is flamable and it could splatter everywhere...
Originally Posted by apachewoolf
pssst yo token . your not black any more...there is no man
Hayabusa! MoFo 4 life!!! the I'll buy your daughter moFo
Blank is offline   Reply With Quote
Old May 24th, 2005, 08:40 PM   #5 (permalink)
am3rican
Banned
Send a message via AIM to am3rican
Im ashamed to admit this, but where is the distributor/fuse box and other electronics located on my car. ive never actually washed an engine bay...lol...so i have no idea where this sh*t is.
am3rican is offline   Reply With Quote
Old May 24th, 2005, 09:02 PM   #6 (permalink)
Blank
Whoa...
Blank's Avatar
fuse box is going to be a big black plastic box labled fuses... other then that watch for any groups of wires, watch where the plugs connect to the wires your MAF sensor(near your intake) or anything else that exen makkes you think electronic.,...
Old May 24th, 2005, 09:55 PM   #7 (permalink)
wildmanee
F.I. Section Whore
wildmanee's Avatar
Pete and others, if you used 100% silicon lubricant it will NOT harm any rubber/plastic components. It is the silicon that has additives mixed in with it that chew away at the plastic and rubber.
wildmanee is offline   Reply With Quote
Old Jun 3rd, 2005, 01:42 PM   #8 (permalink)
Exalta
Avtomat Kalashnikov
Exalta's Avatar
Send a message via ICQ to Exalta Send a message via AIM to Exalta
Wink
I'd like to add a link here for this thread:
How to detail your engine
Just click!
2000 Nissan Exalta Sentra STA (B14) /2003 Nissan X-Trail /
NissanBayan PI
(Click on the links above)
Exalta is offline   Reply With Quote
Old Mar 1st, 2006, 07:21 PM   #9 (permalink)
sybergato
Send a message via Yahoo to sybergato
JRinke I finally got ballzy enough to do it today. I cleaned my bay out n' it started up afterwards. Here are my pics of what I covered, if I should have covered something else, someone please state it. I'd like to be safer next time if I should be.
The two fuse boxes, disconnected positive battery terminal (covered whole thing), intake box, and alternater. I was pretty happy with the outcome, I didn't get the hood too well cause I forgot to do it until last and I had run outa mean green. DON"T FORGET UNDER THE HOOD! Lots of crap under there.
sybergato is offline   Reply With Quote
Old Mar 10th, 2006, 09:08 PM   #10 (permalink)
sybergato
My engine bay definatilly needs a good cleaning. But I'm afraid of screwing up electronics in there.. . .
Old Mar 11th, 2006, 03:06 AM   #11 (permalink)
JRinke
JRinke's Avatar
Send a message via MSN to JRinke
Im with you here Syber (first time I added oil, forgot to put the cap back on...DOH). Can anyone provide pictures of a completey sealed engine bay as in before you do the spray? Or does someone know of a method that offers more control than spraying but a little area that toothbrush? Perhaps a stiff bristle paintbrush and some of the Simple Green or some other grease detergent.
1992 2-Door B13 GA16DE 1.6L 5-speed XE
JRinke is offline   Reply With Quote
Old Mar 14th, 2006, 11:59 AM   #12 (permalink)
MyGreenMax94
Think before posting
MyGreenMax94's Avatar
Adding to this sticky: I use leaf blower to dry the engine bay and especially the electrical components/harness connectors...This will help prevent water from shorting out electrical components.....
MyGreenMax94 is offline   Reply With Quote
Old Mar 14th, 2006, 12:40 PM   #13 (permalink)
sybergato
lol, I'm guessing if I just use a garden hose and try to be carful not to actually AIM it at electronic components I'll be ok??
Old Mar 16th, 2006, 08:27 PM   #14 (permalink)
Matt93SE
Will work for beer
you guys forgot about spraying water on a hot exhaust manifold = BAD.
you also forgot to mention that simple green will corrode bare alumium and leave a thin layer of white aluminum oxide on it.
My website.
Old Mar 24th, 2006, 09:34 PM   #15 (permalink)
pimpride
Nissan Addict
pimpride's Avatar
Send a message via AIM to pimpride
Yea be careful, the last time I cleaned my engine bay I got water somewhere. Maybe it wasn't that, maybe it was the DAMNED WATER STORM that night that forced me through about foot deep water. That was about $300 in damages to get it running (mechanic pricing).
Pics of my car- Red Dragun
Upgrades: New muffler, painted stuff, Pioneer HU, Pioneer Component Speakers, MTX Amp, 2 12" Kicker Comp Subs.
Member's Rides Thread
pimpride is offline   Reply With Quote
!!! KA24DET vs. SR20DET !!! MontyCrabApple SR20DE/DET Engines 242 Sep 6th, 2006 07:38 PM
Engine Knock on Mexican built GA16DE Sentras Pablo14 GA16DE 1.6L Engine 44 Jul 5th, 2006 10:16 PM
Taiwanese...? Jeff Dallas Nissan Enthusiasts 9 Dec 8th, 2004 07:55 AM
HELP: how to clean an engine bay zyg0te General Discussion 15 Apr 9th, 2004 04:19 AM
New Engine , Same Knocking LUVMYTRUCK Truck & SUV 11 Jun 24th, 2003 01:14 PM
