yea... go to a self car wash and choopse the degreeser and if they dont have it then bnring your own, spray it on ,let it sit for a sec to melt some gunk then blast off to clean away junk, remember to be careful with distributor area , wanna make sure u start after u clean up and wet starters or dizzy's dont work too well with water in them
I use a product called Mean Green. I get it from the dollar store for $2.00. It is about the best stuff i've used. It won't damage your paint. Just spray it on, and then hose it off. You may have to use a brush on any thick grease.
so wat part of the engine should I watch out on? anything particular cant be wet at all?
do I have to wait for the bay to be completely dry to start again?
Cover your distributer and plugs with plastic bags and also try not to get water on your starter. I'm pretty sure you can run your car for a bit to dry it out.
Originally Posted by mzanubis
yeah yeah yeah, the important question is... can it reheat my burrito?
if your good (im good ) you can leave the car running while you clean it, if its hot enough, and your careful enough, stray water gets boiled away instantly on the hot engine(its gotta be hot!) be careful, some products are flamable!
Originally Posted by apachewoolf
pssst yo token . your not black any more...there is no man
