Go Back   NissanForums.com :: Nissan Forum > Cosmetics and Show > Car Care
Car Care Information on maintaining your vehicle's appearance
Old Aug 25th, 2004, 12:49 AM   #1 (permalink)
xhris
xhris's Avatar
engine
i was wondering what you guys would suggest i use to clean up my engine compartment (under the hood). I have a 2002 SE-R spec v, but im sure the type of car doesnt matter, i just put it there just in case. Also, how much would a pro detail, in and out cost me?? (and does the pro detail clean under the hood?) thanks.
xhris is offline   Reply With Quote
Old Aug 25th, 2004, 12:55 AM   #2 (permalink)
Slayer2003
Peek-a-boo....
Slayer2003's Avatar
Send a message via AIM to Slayer2003 Send a message via Yahoo to Slayer2003
mainly, pros use a pressure washer for mostly everything non-electrical. ust be sure to put a plastic bag an alot of tape over what you dont want to get wet.
another way, is some engine degreaser, and a metal/boar/plastic bristle brush, depending on the material, will help alot, just dont use exess.
im pretty sure you can use armor all, for the plactic and hoses, but i would think that it would collect a ton of grit n grime considering its a greasy type of stuff.
hopefully you find something that works for you!
Originally Posted by RoadWarrior - ocforums.com
Yes, SATA is faster however..... putting full spec formula one tires on a 1.6L stock honda civic will not make it capable of 200Mph......
SEARCH BUTTON. USE IT OFTEN!
Slayer2003 is offline   Reply With Quote
Old Aug 25th, 2004, 12:34 PM   #3 (permalink)
dange
Send a message via AIM to dange Send a message via MSN to dange Send a message via Yahoo to dange
I personally use industrial degreaser that you are supposed to water down 10 to 1, but I use it at almost full strength, let it sit for about 5 min and wipe it off, and scrub whatevers left, it makes the engine look new. I wouldn’t recommend armor-all because it attracts dirt,
And yeah professional detailers will usually only spray it down with a pressure washer…that is unless you get into the 250-300 dollar range then they often will scrub it all down, but they will also clean all your interior down to the inside of your airvents and make it look almost new. I used to be a professional detailer so you could always take it to me
dange is offline   Reply With Quote
Old Aug 25th, 2004, 01:43 PM   #4 (permalink)
GarrettSER
Are you in Los Angeles?
GarrettSER is offline   Reply With Quote
Old Aug 25th, 2004, 02:48 PM   #5 (permalink)
dange
unfortunatly no... southern az
Old Aug 25th, 2004, 07:47 PM   #6 (permalink)
Boromir
NF SUX DIK
Boromir's Avatar
Detailers here charge 25 bux to steam clean/dry and shine the whole engine bay. and guarantee thier work.
Boromir is offline   Reply With Quote
Old Aug 26th, 2004, 03:48 AM   #7 (permalink)
myoung
NPM Lead Editor/Webmaster
myoung's Avatar
Those guys love to use Armour All...which is the worse thing you can possibly use... it turns everything black into a dull brown after a short time.. nasty.
Unfortunatly there is no easy way to have a clean engine bay other than getting in there and getting dirty.
I usually cover all the electronics with plastic bags with rags inside them for added protection. Then hit it with the lower pressure at the drive in car wash.. usually the spot free selection, two reasons.. less pressure and soft water. Then take soft brushes and scrub everything you can reach.. hit it again with the water... wipe everything down.
One product I really like is CD2 Engine Detailer, I usually hit it with about a half a can afterwards...
Then wipe everything down once again.. let dry... then clean all the silicone hoses with alcohol swabs.. then hit my polished metal parts with polish..
To have an nice engine bay it takes just as much time or more than the normal exterior.
pic
myoung is offline   Reply With Quote
Old Aug 26th, 2004, 10:40 AM   #8 (permalink)
dange
completly true!
i havnt heard of cd2 engine detailer..
but yeah onece i bought an 88 ford escort the engine had never been cleaned so it had a good approx. .25 up to .5-.75 of a centimeter in some places on old baked on oil.
i use the same trick with the plastic bags but i got that engine looking great however in the end the engine was alot cleaner than i was lol,
for stubborn grease and all one thing that ive also been told really works is the areosol oven cleaner, not the no-fume type but the generic el-cheapo stuff
yeah i dont touch armor all ive seen it screw up peoples interior, what i kindof like is "black magic" it seems to work superb.
Old Aug 27th, 2004, 08:46 PM   #9 (permalink)
xhris
xhris's Avatar
wow!! after seeing your engine bay im gonna go by your method. VERY VERY clean!! thanks alot guys.
Old Aug 28th, 2004, 07:24 PM   #10 (permalink)
ThisFlyGuy
my friend uses a power steam spray........just be careful you don't hit the electrical areas....
www.JDMautoworks.com
"JDM Style Inspired"
http://members.rankmyride.com/ThisFlyGuy
ThisFlyGuy is offline   Reply With Quote
Old Aug 29th, 2004, 10:24 AM   #11 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
i cover some electrical with the plastic bags and also roll up some paper towels and put them in my spark plug holes. spray everything with this cleaner called awesome and scrub down what needs to be, rinse, then spray with Gunk Foamy Engine Brite and then rinse again. i usually let the car run for a little bit with the hood open after im done just to dry itself. my engine bay isnt as clean as mike's but its not so shabby
Katana200sx is offline   Reply With Quote
Old Sep 4th, 2004, 01:24 AM   #12 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
I usually don't have a very greasy engine bay. I keep up with it, so there's never really any problem.
Before a show, I'll usually blow out all the excess sand/dirt with compressed air or such, any greasy or dirty parts like the resovoirs get scrubbed with your common household de-greaser, dirty painted/powdercoated objects get wiped down with car wash wipes, and I finish off all rubber and plastic with Armor-All wipes for that shiny look. The Armor all doesn't last very long, but it keeps it shiny for the show.
Ninety-Nine SE-L is offline   Reply With Quote
Old Sep 5th, 2004, 09:59 AM   #13 (permalink)
Matt93SE
Will work for beer
instead of the armor all, I used to use silicone spray lube/protectant. spray it on the hoses and wipe it off after about 5 min so there's no greasy buildup.
when the engine gets dirty, I use gunk engine brite and an old toothbrush to scrub down anything messy- power steering reservoir and around the oil cap, stuff like that... simple green works just as well.
the one major issue is DO NOT GET THESE CLEANERS ON YOUR EXTERIOR PAINT! If you do, re-wax that area as any type of degreaser will strip the wax off and dull your paint.
http://mattblehm.com/pics/old_max/car/good_pics/3.jpg
http://mattblehm.com/pics/old_max/car/old/engine1.jpg
that was my old one that I totalled 4 yrs ago.. now I could care less what it looks like as long as it's fun to drive.. I don't even have pics of the engine bay unless I was doing a writeup for installing a mod or something.
My website.
Old Sep 5th, 2004, 02:07 PM   #14 (permalink)
STRATTON
I WANT BOOST !!!
STRATTON's Avatar
Send a message via AIM to STRATTON
pic[/quote]
real nice engine bay man, clean too ! ohh and a real nice set up.....
COMPRESSED CLIQ
STRATTON is offline   Reply With Quote
Old Sep 6th, 2004, 04:47 AM   #15 (permalink)
myoung
myoung's Avatar
There are some good products..but no real subsitute for hard work and simply keeping it up..
92 1.6 engine vs 94 1.6 engine ? 92sentra92 GA16DE 1.6L Engine 2 Jul 14th, 2003 10:26 PM
trouble starting engine, engine dies when you give it gas LoOoD GA16DE 1.6L Engine 6 Jun 19th, 2003 05:44 PM
ga16de engine questions vashna GA16DE 1.6L Engine 1 Jun 17th, 2003 02:46 PM
Hurt engine, what do u think is wrong in it? pmftv E/CA-Series & GA16i Engines 5 May 23rd, 2003 12:35 AM
F1 engine plays a tune Mudge Off Topic 7 Dec 18th, 2002 02:33 AM
